Je viens de passer tapatalk en version 4.1.0
Please grab this latest one as it fixed numerous issues especially now you can reply post, and topic listing index is fixed also. Plus few others.
We have also identified some other issues and is working on it on parallel.
Mise a jour de tapatalk
nous sommes a présent en version 4.20
suite au changement du serveur je viens de passer en version 4.0.5
Mais j'ai toujours de ralentissement a cause de apache qui prend toutes les ressources machines
J’espère qu’avec cette mise a jour ce la résoudra le problème
Notes :
[Official] QTS 4.0.5 build 1023 SMB for TS-x69, x70, x79 series
[Change log]
[Enhancement]
1. Legacy volume capability enhancement
2. Some minor translation errors
3. Enhance SMART temperature compatibility
4. Enhance QPKG installation compatibility
[Bug fixed]
Fixed - Upgrade from 3.8.3 to 4.0.4, RAID 10 shows Not Active,but data can be accessed
Fixed - Network port mapping
Fixed - Create block-based LUN,switch to storage pool will show Free size -1
Fixed - TS-469L NAS icon can not display on Chassis View
Fixed - Upgrade from 3.8.4 to 4.0.4, deleting legacy volume takes long time
Fixed - Disk should can be back to normal state after bad block scanning
Fixed - Error Log shows "Examination failed(Cannot unmount disk)" by Volume
Fixed - Encryption key File can not unlock Encryption Volume that been created from Soho firmware, after update to SMB v4.0.4
Fixed - Lost iSCSI connection in XenServer when upgrading from 3.8.4 to 4.0.4
Fixed - System migration issue
Fixed - Unexpected occasional reboot in some condition
Fixed - Xenserver iSCSI compatibility improvement
Fixed - Specify 2+ layers depth of path for Shared Folder, Shared Folder UI view incomplete
Fixed - Kernel crash after remove SAS cable and then remove iSCSI LUN which is initializing
Fixed - Cannot connect to Time Machine server using OSX 10.9
Fixed - Can use USER account to connect AFP
Fixed - [ WD10JFCX ] TS-1679U Rapid Test result: Fatal or unknown error (SMB)
Fixed - Speed down for ICRC error, Disparity and 10B8B error
Fixed - When HDD is in self test mode, retry 10 times if get HDD S.M.A.R.T fail
Fixed - Fix the long SATA resume time
Fixed - Fix SSD in PCH sometimes negotiate speed is 1.5G when plug out then plug in.
Notes :
[Change log]
[Enhancement]
[Bug fixed]
Je viens de passer le serveur en version 4.0.7
Mise a jour de bug mineur
Je viens de passer tapatalk en version 4.4.0
Le serveur a été inaccessible depuis hier vers 18h
en effet j’étais passé en version 4.1 bêta, mais j'avais constater des erreur, je suis donc repasser a une version plus ancienne a savoir la 4.0.7, mais la plus moyen de redémarrer le web du serveur.
Je suis donc retourner en version 4.1 bêta, et la parti web semble a nouveau fonctionnel.
Je suis a présent en attente d'une version 4.1 final en espérant que tous fonctionne a nouveau
Je viens de passer la base MYSQL en version 4.1.13
Reste a voir si tous fonctionne comme il faut
Si il n'y aura pas d'erreur SQL, affaire a suivre
- SONNY
J'ai un problème on va dire,voir deux,
c'est pas grave mais je préfère le signaler:
sur les dates,ça me dit que ma dernière visite est du 29 avril
alors que je viens tous les jours,
le décalage est toujours le même de jour en jour.
L'autre est quand je poste un message j'ai une page qui apparaît
Erreur générale
SQL ERROR [ mysql4 ]
Unknown column 'topic_id' in 'field list' [1054]
Une erreur SQL est arrivée en chargeant cette page. Contactez l’administrateur du forum si ce problème persiste.
mais en fait ça l'envoi normalement
Erreur générale
pour le problème MYSQL je pense que c'est réglé, dit moi si cela t'arrive encoreSONNY a écrit :J'ai un problème on va dire,voir deux,
Erreur générale
Pour la date j'ai comme info que tu est venu le 04 mai...
cela semble bon a présent.
- SONNY
Pour la date c'est pareil,dernière visite le 30/04,c'est pas grave,
c'était juste à titre indicatif
pas de changement pour le message d'erreur,pas grave non plus,
je peu envoyer les message
SONNY a écrit :Pour la date c'est pareil,dernière visite le 30/04,c'est pas grave,
Je viens de vider les cache et de re initialiser les table SQL
Peut tu vider tes caches de ton coté et voir se que cela donne, car perso, je ne voie plus rien de mon coté qui bloque
Tu utilise quoi comme navigateur internet?
- SONNY
Pour la date c'est bon,j'utilise Google Chrome
j'ai toujours le message,te prend pas le choux ça fonctionne quand même
ok je tacherais de faire des essais avec chromeSONNY a écrit :Pour la date c'est bon,j'utilise Google Chrome
- SONNY
Salut,je viens de poster et je n'ai plus le message d'erreur
edit: Merde si,il viens de revenir,pas grave ça fonctionne
curieux que cette affaire.SONNY a écrit :Salut,je viens de poster et je n'ai plus le message d'erreur
il faut vraiment que je creuse un peut plus
Car pour moi cela fonctionne avec firefox, et safari
