J'ai un ensemble de matériel JBL à vendre
Faire offre
JBL
- Dav
Re: JBL
Infos prises sur le net comme ça c'est encore plus précis
- Les Hps ovales
3 voies
Dimensions 25.5 cm x 16.5 cm
Types Gto 963MkII
Super Solid-state
Tweeter Titanium Composite
Tweeter Titanium-Composite Cone
Tweeter Size :1-3/4"
Speaker Impedance :4 Ohms
Amplifier Power Range :5 – 175W RMS
Frequency Response 45Hz – 21kHz
Sensitivity 92dB
- Le Sub
Dimension 31.5 cm
Type LC-S1250W
12" Loud + Clear Series Component Subwoofer
Power Handling: 480W peak / 120W RMS
Frequency Response 38-500 Hz
Sensitivity: 93 dB
Top Mounting Depth: 5-3/16"
Impedance: 4 Ohms
Polypropylene Cone
Sealed Box Volume: 1.25 cu. ft.
Ported Box Volume: 1.75 cu. ft.
- L'amplie
65W x 2 Automotive Power Amplifier ,
Built-in Electronic Crossover ,
Selectable Bass Boost ,
Floating-Ground Factory-Head Unit Interface ,
Triple-Threat Protection Circuitry ,
2-Ohm Stable ,
Power Output,
4 Ohms: 65W x 2 ,
Peak Power Output: 300W ,
Total Harmonic Distortion: 0.10% ,
Frequency Response: 10Hz-20kHz ,
Signal-to-Noise Ratio:>90dB
- Les Hps ovales
3 voies
Types Gto 963MkII
Super Solid-state
Sensitivity 92dB
- Le Sub
Dimension 31.5 cm
Type LC-S1250W
Sensitivity: 93 dB
Impedance: 4 Ohms
Polypropylene Cone
- L'amplie
2-Ohm Stable ,
Power Output,
4 Ohms: 65W x 2 ,
@+ Dav
