#196 Message par flacon030 »
Je viens de faire la mise a jour du serveur QNAP qui passe en version 3.4.4
[Version & Build]
3.4.4 Build0718
[Checksum]
TS-439: 1657309367
[What's New?]
- none
[Enhancements]
- [ElephantDrive] ElephantDrive version updated to v2.1.5.
- [AFP] Added "AFP DHX2 support" to allow access to the NAS from Mac OS X Lion 10.7. The Time Machine backup for Mac OS X Lion 10.7 will be ready on the official firmware v3.5.0.
- [RAID Management] RAID 10 performance has been improved.
[Major Bug Fixes]
- Random dropping of hard drives during system startup for the NAS using certain models of Hitachi and Seagate hard drives, including ST2000DL003, HDS723020BLA642, HDS723030ALA640.
- [AD] The NAS cannot join the Active Directory if the domain user name used to join the AD domain contains Russian characters.
- [AD] If Active Directory authentication error occurred, users can update the NAS firmware to v3.4.4 and join the NAS to the AD domain again to solve this problem.
- [AD] Domain users cannot access a subfolder after the local admin permission has been removed from the folder.
- [AD] The shared folders cannot be accessed by the domain groups after re-applying the shared folder permission.
- [RAID Management] The NAS will not rebuild a RAID volume if the encrypted volume is locked.
- [SAMBA] Turning on or off the printer will cause Samba disconnection and interrupt ongoing data transfer.
- [SAMBA] File name rename issue by using Windows 7 Windows Explorer.
- [NFS] NFS disconnection during data transfer.
- [RSYNC] Backup by Rsync failed when synchronizing a single large file and the file content is different between the source and the destination.
- [Network UPS] The NAS server which is configured as network UPS master failed to inform the network UPS slave to shut down when a critical power event occurred.
- [Resource Monitor] Fixed the incorrect CPU temperature issue (TS-x59 Pro+, TS-x59 Pro II).
- [Web File Manager] Supports extracting bz2 files by Web File Manager.
[Known Issues]
- [Surveillance Station] The IP camera Y-CAM Generic V2 will be disconnected when selecting the channel on the Live View page.
- [AD] When advanced folder permission is enabled, the domain group permission for Microsoft office files on the NAS will be removed after one of the domain group users modifies the files.
#197 Message par flacon030 »
Le firmware 3.5.0 bêta viens d’être installé sur mon QNAP.
[WHAT'S NEW?]
-iSCSI LUN backup with one-time snapshot
-Antivirus protection
-LDAP client
-Syslog server
-RADIUS server
-TFTP server
-External drive encryption
-IM Robot for system status and notifications (Windows Live Messenger)
-Real-time Remote Replication (RTRR) for ARM-based NAS
Note: If you have previously created more than 32 RTRR jobs on the x86-based NAS, the existing jobs (no. 33-64) will be deleted after updating the NAS firmware to version 3.5 or above.
[ENHANCEMENTS]
-Enhanced DHCP server supporting TFTP
-Enhanced external drive backup with multiple drive support
-New camera support list for Surveillance Station
AXIS 207MW, 209FD(-R), 209MFD(-R), 210, 210A/ 211A, 211/ 211W, 211M
AXIS 213 PTZ, 216FD(-V), 216MFD-V, 221, 223M, 225FD, 233D, 241Q
AXIS M1054, M1103, M1104, M1113, M1114, M3011, M3014, M3113-R
AXIS M3203(-V), M3204(-V), M7001
Cisco PVC-300, WVC-210, PVC-2300/ WVC-2300
D-Link DCS-910/ 920, DCS-3410 A1, DCS-5610, DCS-6110, DCS-6111
iPUX ICS-1100, ICS-1110, ICS-1300, ICS-130A, ICS-1600, ICS-1700, ICS-6000
LevelOne FCS-0010/ WCS-0010, FCS-0020/ WCS-0020, FCS-0030/ WCS-0030
LevelOne FCS-1091/ WCS-1091, FCS-5030
Linksys PVC-300, WVC-210
TRENDnet TV-IP410(W), TV-IP422(W)
VIVOTEK FD7160, IP7133, IP7134, IP7138, IP7139, IP7151, IP7160
VIVOTEK IP7361, IZ7151, PZ7152, SD7151
[MAJOR BUG FIXES]
- Renaming a file causes the file to be selected by Windows Explorer on Windows 7
- IP address of network UPS server cannot be applied.
- Domain users cannot access a subfolder after the local admin permission has been removed from the folder
- Y-CAM Generic V2 will be disconnected when selecting the channel in Live View page.
#198 Message par flacon030 »
Mise a jour du firmware du qnap
Tous c'est bien passé
[Version & Build]
3.5.1 Build1002
[Checksum]
TS-439: 3990803848
[What's New?]
- None
[Enhancement]
- [AFP] Shortened the waiting time to connect to the NAS from Mac OS X 10.7 Lion via the AFP protocol.
- [LDAP] Enhanced the compatibility with Apple Open Directory.
- [RTRR] The real-time remote replication feature supports Mac OS X 10.7 Lion FTP server.
- [Web File Manager] Moving the files on the same disk volume by Web File Manager becomes faster.
[Major Bug Fixes]
- [ACL] Folder owner permission became invalid after changing the upper layer folder permission.
- [AD] Users cannot login Active Directory when the password contains a space character.
- [iSCSI] An iSCSI LUN larger than 2TB cannot be formatted by regular format on Windows.
- [Access Right Management] The user group members became invalid after one of the user accounts was deleted.
- [Access Right Management] The host access control settings for an external drive cannot be stored after system reboot.
- [Download Station] Fixed the connection issue with RapidShare.com for file download.
- [LDAP] The LDAP group list cannot display UTF-8 characters correctly.
- [Surveillance Station] Added missing camera models from 3.5.0, D-Link DCS-900(A/ B1/ B2) and Panasonic BL-C111.
#199 Message par flacon030 »
Je viens d'ajouter un petit module plugmedia sur mon profil
Cela permet a vous utilisateurs de voir toutes mes photos FORD sur mon propre serveur
Tous les meeting, et toutes mes restaurations y sont
C'est la dernière petite icône noir sous mon profil
#200 Message par flacon030 »
petite mise a jour
Dans les statistiques de l'index de forum, je viens de placer les résultats en rouge.
C'est beaucoup plus visible
#201 Message par flacon030 »
je viens de passer l'annuaire de la version 0.1 a la version 1.0.0
Abandon des tableaux pour une structure 100% xhtml dans annuaire_view_cat.html
Ajout d'un message en cas de tentative d’édition d'un lien sans en avoir l'autorisation
Ajout d'un message en cas de tentative de suppression d'un lien sans en avoir l'autorisation
Ajout de deux permissions globales afin de donner la possibilité d'éditer/supprimer ses propres liens
Ajout de deux permissions globales afin de donner la possibilité d'éditer/supprimer des liens pour des membres autre qu'administrateurs
Ajout de deux permissions globales afin de donner la possibilité d'éditer/supprimer des commentaires pour des membres autre qu'administrateurs
Ajout de la miniature du site dans les résultats de recherche
Ajout des boutons bbcode dans le formulaire de postage d'un nouveau site
Ajout des boutons bbcodes persos dans le formulaire de postage des commentaires
Ajout du fichier "no_flag.png" manquant (syndrome de la croix rouge sous iE)
Correction d'une condition dans acp_annauire.php provoquant un message d'erreur en cas d’édition d'une catégorie après une conversion depuis l'annuaire PhpBB2
Correction des requêtes de désinstallation
Correction des liens des sites affichés lors d'une recherche
Correction du paramètre $forum_id envoyé à generate_smilies() dans annuaire_comment.php
Correction du script de migration de l'annuaire phpBB2 afin de prendre en compte les nouveaux noms de drapeaux depuis la version 0.2.0
Correction du script de mise à jour afin de prendre en compte les nouveaux noms de drapeaux depuis la version 0.2.0
Corrections diverses dans les fichiers de langue anglais
Mise à jour du script de migration depuis l'annuaire phpBB2
Remplacement de file_get_contents() par une boucle while et fgets() pour une detection plus rapide du lien réciproque
Remplacement de $_SERVER['HTTP_HOST'] par $config['server_name']
Remplacement de is_writable() par phpbb_is_writable() (is_writable() pouvant ne pas fonctionner correctement sous windows)
Remplacement de header() par send_status_line() ajoutée par phpBB 3.0.8 qui gère plus de cas de figure
Remplacement des liens texte "editer" et "supprimer" par des images (comme dans viewtopic)
L'adresse IP des posteurs de commentaires ne sont plus visible que par les admins, mais sont désormais visible par tout membre ayant les permissions m_info
Intervertion des codes d'erreur 404 avec 410, dans le cas où une catégorie n'est pas spécifiée/n'existe plus
bruno77
#202 Message par bruno77 »
tu en as fais un paquet "effe" "effe"
#203 Message par flacon030 »
Bien j'essaye de rendre le forum le plus agréable, et le plus complet possible.
Rien n'est trop beau pour vous
#204 Message par flacon030 »
juste pour vous signaler que le forum vient d’être mis a jour
il viens de passer de la version 3.0.9 a la version 3.0.10
Tous semble s’être bien passer
Merci de me signaler tous problèmes rencontré
#205 Message par flacon030 »
Le Qnap viens de passe en version 3.6.0
comme d'habitude tous semble s'etre bien passé.
Si vous constatez un probleme, merci de me le signaler
Release Notes
[Before Getting Started]
- Always have a full backup before updating your system
- Remember to clear the browser's cache
[Version & Build]
3.6.0 Build0210
[Checksum]
TS-219/219P/219P+/219P II: 3810091059
[What's New?]
- VPN Service (with PPTP and OpenVPN services)
- LDAP Server
- Photo Station
- Music Station
1. Web streaming
2. USB speaker/sound card support for local playback
3. Support QMobile Music Remote
- QPKG Center with revamped UI for easy online installation
- MyCloudNAS 1.2
1. Email invitation and password reset functions
2. Support MyCloudNAS Connect Windows utility for remote access
- Enhanced Web File Manager
1. Public file sharing link with expiration time and password protection
2. Advanced upload function for over 2GB file
- Support Storage Plug & Play via QNAP Finder for Windows (requires QNAP Finder v3.5.0.209 or later)
[Enhancement]
- Added RTRR & Rsync bandwidth control
- Updated the built-in UPnP TwonkyServer to 6.0.38
- Added Surveillance Station camera support for the following new IP cameras:
ACTi ACM-1231/ 1232, ACM-4200/ 4201, ACM-5601/ 5611, ACM-8201/ 8211, ACM-8511, TCM-4301; AXIS 214 PTZ/ 215 PTZ(-E), 241S, M1054, M5013, M5014; Brickcom CB-100Ae, CB-100Ap, CB-102Ap, FB-100Ae, FB-100Ap, FB-130Ap, FB-300Ap, FD-100Ae, FD-100Ap, FD-130Ae, FD-130Ap, MD-100Ap, OB-100Ap, OSD-040D/E, PZ-040D/E, VD-100Ap, VD-130Ae, VD-130Ap, WCB-100AP, WFB-100Ae, WFB-100Ap; D-Link DCS-942L; iPUX ICS-2230; LevelOne FCS-3061; Linksys WVC54GCA; Panasonic BB-HCM705, BB-HCM715/ 735, BL-C1, BL-C10, BL-C20, BL-C30(K1), BL-C131, BB-HCM371, BB-HCM311, BB-HCM331, BB-HCM381, BB-HCM403; TOSHIBA IK-WB21A; VIVOTEK FD7131, IP7131/ 7132, IP7133/ 7134, IP7135/ 7137, PT7135/ 7137, IP7138/ 7139, IP7142, PZ7151/ 7152, IP7160/ 7161, IP7361, MD7530, MD7560, SD8111/SD8121 FD8133, FD8134, IP8151, IP8161, FD8161, IP8162, IP8330, FD8361, FD8362, IP8362.
[Major Bug Fixes]
- HDD standby mode will be interruptted daily by UPnP router port forwarding service.
#206 Message par flacon030 »
Encore une petite mise a jour du qnap
Rien de nouveau juste des bugs de corrigés.
Tous semble s'être bien passé.
Mais comme d'habitude n'hésitez pas a me signaler tous problèmes.
Version 3.6.1
Release Notes
[Version & Build]
3.6.1 Build0302
[Checksum]
TS-219/219P/219P+/219P II: 3438494664
[What's New?]
- None
[Enhancements]
- Web File Manager supports multiple file upload in HTTPS
- Disk reordering is supported in the same RAID configuration
[Major Bug Fixes]
- [External Storage Device] Multiple USB devices might not be concurrently detected in TS-x19P, TS-x19P+, and TS-x19PII.
- [External Storage Device] Format the external drive with encryption could fail with USB 3.0 port connection.
- [Port Trunking] DHCP Server did not function in Port Trunking mode.
- [Port Trunking] In 802.3ad, NAS could not obtain a valid DHCP IP address when switches to another subnet.
- [Music Station]Playback status could not be displayed correctly in Local Playback mode when user uses the One Touch Copy button.
- [Web File Manager] If the NAS was joined to an AD domain, domain user groups became the local user groups in access right configuration of shared folders.
- [Surveillance Station] Vivotek IP 7330 was missing from the supported camera list.
- [Live Update] NAS might become unresponsive after firmware live update.
- [WebDAV] WebDav permission was incorrect when share folder was assigned to a user group.
#207 Message par flacon030 »
Je viens de m'apercevoir d'un bug sur le forum
Sous safari et sous chrome le forum ne retiens pas les identifiants des membres
si bien qu'un autre problème survient, si vous tentez de modifier votre position sur la carte des membres vous avez une erreur suivante
SQL ERROR [ mysql4 ]
[0]
Se qui est normale vu que vous essayer de modifier votre position alors que vous n’était plus connecté au forum, si bien que la base mysql répond (0)
Il faut que je vérifie si ce problème arrive aussi avec d'autres navigateurs (exemple internet exploreur,ect...)
mais cela fonctionne comme il faut sous firefox si en attendant vous voulez modifier votre position sur la carte
prochainement je verrais si je peut intégrer des bouton radio de connexion a la carte du genre
cela permettra de voir si vous était déjà sur la carte ou pas
Turbo rs
type véhicules : focus + escort + sierra
#208 Message par Turbo rs »
je croyais que tu etais en vacances?88.........Vacances tu sais le truc ou on fait rien sauf se reposer "fou"
Albert EINSTEIN
#209 Message par flacon030 »
Turbo rs a écrit :je croyais que tu etais en vacances?88.........Vacances tu sais le truc ou on fait rien sauf se reposer "fou"
heu....
Oui je suis en vacances.
Du coup je m'occupe de se qui me plait ..Mgreen..
Turbo rs
#210 Message par Turbo rs »
"malade"
Albert EINSTEIN
