SONNY
#301 Message par SONNY »
Salut,pour l'instant pas de soucis de mon côté ..merci..
#302 Message par flacon030 »
Mise a jour majeur du seveur
QTS 4.4.2.1270 build 20200410
[Important Notes]
- For the status of QTS updates and maintenance for your NAS model, visit https://www.qnap.com/en/product/eol.php
- To learn more about NAS models that support the TL-D800C, TL-R1200C-RP, TL-D400S, TL-D800S, TL-D1600S, TL-R400S, TL-R1200S-RP, see the Compatibility List at https://www.qnap.com/en/compatibility-expansion
- We have fixed the vulnerabilities in the following apps to ensure your data security: Surveillance Station, QVPN Service, Qfiling, Qsync Central, QcalAgent, and IFTTT Agent. To continue using these apps, go to the App Center and update them to the latest version.
- For more information on the kernel versions for NAS models that QTS 4.4.2 supports, see https://www.qnap.com/en/release-note/kernel
- Removed the following applications from App Center due to PHP 7 updates in QTS 4.4.1: "phpEasyProject", "Dolphin", "CMS Made Simple", "Vtiger CRM", "iStat", "PostgreSQL 9.3.13.3", and "ownCloud".
- Due to compatibility issues, the following applications have been removed from the App Center in QTS 4.4.1: FileFlex, MantisBT, SugarCRM, Xeams, DokuWiki, and Azure Storage.
- Once you update QTS to 4.4.1 (or later) on the TS-1635AX, you will not be able to downgrade QTS to versions earlier than 4.4.1.
- Removed support for Plex Home Theater from HybridDesk Station.
[New features]
VJBOD Cloud
- VJBOD Cloud now supports the Cynny Space cloud service.
- VJBOD Cloud now supports the hicloud cloud service.
- VJBOD Cloud now supports the Qcloud IT cloud service.
Storage management
- Added support for QXP400 and QXP800 expansion cards.
- Added support for TL-D400S, TL-D800S, TL-R400S, TL-R1200S, and TL-D1600S SATA expansion units.
- Added support for TL-D800UC, TL-R1200UC-RP and TL-R1200UC USB expansion units.
Control Panel
- Added the "veto files" option to enable administrators to hide certain files to prevent user access to certain files via Samba.
- Added support for QXP expansion cards.
- Removed support for iTunes Server.
File Station
- Users can now keep files in reserved cache to enhance access performance.
iSCSI and Fibre Channel
- Added an asynchronous I/O option to the virtual disk creation wizard for optimal system performance.
[Enhancements]
QTS
- To ensure system security, the default password of the "admin" account is now the first MAC address without special characters. All letters should be uppercase. For example, if the MAC address is AA:BB:CC:11:22:33, the default password will be AABBCC112233. You can check the MAC address via Qfinder Pro or from the sticker on the device.
- Modified the instructions in the "Backup/Restore" topic in Help Center.
- Users can now switch between QTS and QTS hero on the QTS hero NAS.
Storage management
- Added support for SSD lifespan estimation in S.M.A.R.T. disk migration.
- Optimized IronWolf Health Management (IHM) statistics calculation mechanism.
- Optimized storage pool creation workflow when using an external storage device.
- Optimized the Secure Erase workflow in Storage & Snapshots.
- Modified user interface strings in Storage & Snapshots to enhance usability and improve workflow.
- Modified user interface strings in Storage & Snapshots to optimize the workflow of safe storage pool detaching.
- Storage & Snapshots now displays both the status and the category of disks.
Control Panel
- Added an info tip to remind users to reserve enough space for a Time Machine backup folder.
- Changed multiple system default settings to enhance system security, including TLS version, HTTP compression, and password policy.
[Fixed Issues]
- QuMagie could not display more than 10 albums when users selected albums for adding photos.
- QuMagie would take a long time to load albums when users uploaded a large number of photos of various types.
- Photos downloaded from QuMagie would not have the original sizes even when users chose to download the original files.
- The output of the "/proc/meminfo" command would still include non-zero writeback memory values after iSCSI storage tests were completed.
- Share links created in File Station would not include external port numbers.
- Users could not create Microsoft Office documents in the Qsync folder in File Station.
- Non-administrator users could not upload folders to the subfolders of the Home folder.
- Users could not download files from Qsync team folders in File Station.
- Users could not upload files to folders shared via SmartShare link in File Station.
- QTS would stop responding when users copied a volume snapshot, and the cloned volume would have the same name as the original volume.
- Storage & Snapshots could not display the statistics for Qtier auto-tiering.
- Control Panel would show the status of "Unix/Linux NFS" as disabled even if only certain versions of NFS were disabled.
[Known Issues]
- The NAS will run out of memory after users perform a live update from QTS 4.4.2.1262 build 20200402. To work around this issue, QNAP recommends performing a manual update instead.
[Other Changes]
Storage & Snapshots
- Instead of "REXP", QTS now uses "EXDR" as the abbreviation for external storage devices.
#303 Message par flacon030 »
Mise a jour du serveur Qnap
QTS 4.4.2.1320 build 20200529
[Important Notes]
[Fixed Issues]
- QM2 SSD expansion card sometimes detected only one or neither of the installed M.2 SSDs after users updated QTS to 4.4.2.1310.
- Users could not update virus definitions on the NAS models with ARM processors after updating QTS to 4.4.2.1312.
cosworth t35
#304 Message par cosworth t35 »
..merci..
#305 Message par flacon030 »
Je viens de passer le forum en PHPBB3.3.1
Il semble que cela se soit bien passé
Bon surf a tous
#306 Message par flacon030 »
QTS 4.4.3.1439 build 20200925
[Important Notes]
- For more information on the kernel versions for NAS models that QTS 4.4.3 supports, see https://www.qnap.com/en/release-note/kernel
- After reaching their end of support in July 2020, Notes Station and Qnotes have been removed from QTS App Center, Google Play, and Apple App Store. We recommend using Notes Station 3 and Qnotes 3 to benefit from the next-generation note-taking features. For details on how to transfer your notes from Notes Station 2 to Notes Station 3, see the following tutorial: https://www.qnap.com/en/how-to/tutorial ... -station-3
[Enhancements]
- Added an infotip to explain the discrepancies between storage space sizes on the NAS and those on the LUN host.
[Fixed Issues]
- Storage & Snapshots could not correctly display the space usage of block-based thin LUNs.
- Storage pools on the TR-004 would become abnormal after the NAS woke up from sleep.
- QTS would not send notification messages via SNMP when users disconnected an Ethernet cable from the NAS.
- Users could not perform a file system check for an unmapped file-based iSCSI LUN.
- Users could not join the NAS to an Active Directory domain when the domain NetBIOS name contained special characters.
- Syslog Server would constantly send error messages after the log file exceeded the allocated size.
- General users could establish an SSH connection even without administrator privileges.
- Storage & Snapshots would not display a device appearance graphic for the TS-932PX.
- Guest users could not access shared folders where they were granted access permissions.
- Users could not re-map an iSCSI LUN to another iSCSI target.
- Camera channels purchased by users would constantly disappear from Surveillance Station.
- Virtual disks would display an abnormal status after users disconnected iSCSI targets.
- QTS could not correctly display the CPU temperature of the TS-h977XU.
- Users could not upload files to a WebDAV server when choosing to skip duplicate files.
#307 Message par flacon030 »
Mise a jour du forum en version 3.3.2 dernière version en date
Cela semble fonctionner comme il faut
Bon surf a tous
Bonjour,
phpBB.com a annoncé les sorties de phpBB 3.2.11 et 3.3.2. Ces versions sont des version de maintenance et de sécurité de la branche 3.2.x et 3.3.x qui corrigent un problème de sécurité, introduit un renforcement du code et résout divers problèmes signalés dans les versions précédentes.
Les versions précédentes de phpBB, en commençant par 3.2.0, ajustaient la façon dont le formatage était supprimé dans la fonction « strip BBCode ». Si cette fonction est utilisée par des extensions phpBB, cela peut potentiellement conduire à ce que des entités HTML soient décodées et encodées de manière inattendue et donc entraîner une faille de type XSS réfléchi. phpBB.com tient à remercier n0bodysec de leur avoir divulgué cela de manière responsable.
Un renforcement du code a été introduit dans les paramètres de configuration du PCA pour la fonctionnalité Jabber. La page n'exposera plus le contenu de la communication avec le serveur Jabber lors du réglage des paramètres. phpBB.com remercies Cory Billington de leur avoir signalé ce problème via HackerOne.
Pour phpBB 3.3.2 seulement, les problèmes résolus incluent, entre autres, une dépendance circulaire lorsque les tâches cron dépendent du contrôleur « helper », des problèmes avec les menus déroulants, des marges incohérentes lors de l'utilisation du zoom dans un navigateur et une erreur lors de la génération de sauvegardes sur PostgreSQL 12+.
En plus de cela, les permissions suivront désormais un ordre plus naturel dans le PCA et la taille maximale autorisée d'un fichier joint sera affichée aux utilisateurs.
Comme vous le savez peut-être, la branche 3.2 approche presque de sa fin de vie et ne recevra plus de mises à jour de sécurité après le 7 novembre 2020. Nous souhaitons rappeler à tout le monde de migrer vers phpBB 3.3 dès que possible.
La liste complète des modifications est disponible dans le fichier « changelog » présent dans le répertoire « docs » contenu dans l'archive de la version publiée.
Vous pouvez trouver les principaux changments de ces versions sur le wiki :
https://wiki.phpbb.com/Release_Highlights/3.3.2
https://wiki.phpbb.com/Release_Highlights/3.2.11
Et consulter la liste de tous les problèmes résolus sur l'outils de suivi :
phpBB 3.2.x : https://tracker.phpbb.com/issues/?filter=15490
phpBB 3.3.x : https://tracker.phpbb.com/issues/?filter=15390
Nos packs Fr arrivent sous peu !
#308 Message par flacon030 »
Mise a jour du serveur NAS
QTS 4.5.1.1465 build 20201024
[Important Notes]
- For more information on the kernel versions for NAS models that QTS 4.5.1 supports, see https://www.qnap.com/en/release-note/kernel
- Removed HappyGet from the App Center due to changes in Google extension policies.
- vQTS does not support updating to 4.5.1 and later versions. QNAP will only release security updates for vQTS. We recommend using QuTScloud as an alternative virtual NAS solution. For details, go to https://www.qnap.com/solution/qutscloud-hypervisor
- Starting from 4.5.1, QTS is no longer compatible with the following applications: DJ2 Console, CodexPack.
[Fixed Issues]
- After a system update to QTS 4.5.1, users could not run applications that lacked digital signatures.
- App Center would still install applications that lacked digital signatures even if users did not allow such an installation in the App Center settings.
- System Event Log would erroneously report the failure of a non-existent power supply unit on certain expansion enclosures.
- The number of Python processes would increase abnormally after users changed the system port number, causing OOM (out of memory) issues.
- Users could not specify a destination for log retention if all volumes were encrypted.
- App Center could not enable WirelessAP Station.
- Fixed a command injection vulnerability (CVE-2020-2508).
- Upon every user login, QTS would display a message to remind users to configure password retrieval settings.
[Known Issues]
- QTS displays an inaccurate warning message about the failure to enable Media Streaming Add-on after system update from 4.4.3 to 4.5.1. To work around this issue, you only need to manually enable the add-on in the App Center.
- Users cannot add NAS models running QTS 4.5.1 to vSphere Client (HTML5).
- Users cannot add NAS models running QTS 4.5.1 to Snapshot Agent.
- App Center cannot enable Mustang Card User Driver after a system update from QTS 4.4.3 to QTS 4.5.1.
- Users cannot install OpenVINO Workflow Consolidation Tool (OWCT) in the App Center.
#309 Message par flacon030 »
Je viens de passer le forum en version PHPbb3.3.3 la dernière version a ce jour
#310 Message par flacon030 »
Je viens de passer le forum en version PHPBB 3.3.4 la dernière version a ce jour
#311 Message par flacon030 »
Mise a jour du NAS Qnap 682
QTS 4.5.4.1787 build 20210910
[Important Notes]
- We have fixed the vulnerabilities in the following apps to ensure your data security: Qsync Central and IFTTT Agent. To continue using these apps, go to the App Center and update them to the latest version.
- For more information on the kernel versions for NAS models that QTS 4.5.4 supports, see https://www.qnap.com/en/release-note/kernel
- Removed the following applications from App Center due to PHP 7 updates in QTS 4.4.1: phpEasyProject, Dolphin, CMS Made Simple, Vtiger CRM, iStat, and ownCloud.
- QTS 4.5.4 does not support earlier versions of QVR Client. After updating QTS to 4.5.4 (or later), Surveillance Station users can download and install the latest version of QVR Client from the QNAP website: https://www.qnap.com/en/utilities/surveillance
[Fixed Issues]
- File Station could not automatically check the validity of folder names when users mounted QuDedup shared folders.
- When users mounted a QuDedup file as a shared folder in File Station, the "." character (period) in the folder name would automatically change to the "," character (comma).
- Share links in File Station would still display local IP addresses even when users chose to use domain names.
- Sorting results in File Station were not consistent with those in SMB shared folders.
- iTunes could still discover the NAS even after users updated QTS to 4.5.4.1723, which did not support iTunes Server.
- Users sometimes could not enable the home folder at the first attempt.
- SNMP OID values about CPU usage were not consistent with the values displayed in Resource Monitor.
- On the NAS models that support a maximum of 16 snapshots per volume or LUN, users could not apply snapshot settings when Smart Versioning was selected as the snapshot retention policy.
- QTS could not display certain strings in Control Panel when the system language was set to Japanese.
- Users sometimes could not upgrade a storage pool to a Qtier storage pool.
- Users could not change their passwords when entering their usernames without case sensitivity.
- The NAS would automatically restart when users connected to an iSCSI target protected by CHAP authentication.
- Users could not enable NFS service for shared folders if folder paths contained Simplified Chinese.
- In File Station, non-administrator users could not edit files via Office Online.
- QTS could not register the NAS in DNS even after users joined the NAS to a domain and enabled automatic DNS registration.
- SNMP sometimes could not function normally even after users enabled SNMP in Control Panel.
- Media Viewer would display incorrect resolution information after users changed the resolution of online streaming.
- Users could not sort search results in File Station after performing advanced search.
- Network & Virtual Switch could not correctly indicate the position of a connected Ethernet port in the device drawing of the TS-453BU.
- QTS could not correctly display the system fan speeds of the TS-882BR in Control Panel > System > System Status > Hardware Information.
- File Station would display empty version history for files on a volume that had been backed up by snapshots.
- File Station could not correctly display the content of a shared folder if users went to Recycle Bin before accessing this shared folder.
- Users could not refresh the Recycle Bin in File Station.
SONNY
#312 Message par SONNY »
..merci.. "dieu"
#313 Message par flacon030 »
grosse mise a jour du serveur qui passe en version QTS 5
QTS 5.0.0.1808 build 20211001
[Applicable Models]
- TS-X75, TS-531P, TS-X73A, TS-X90U, TS-X53S, TS-XA51, TS-XA82, TS-X89U, TS-X88, TS-X85U, TS-X85, TS-X82S, TS-X82, TS-X77, TVS-X71, TS-X53B, TS-X51A, TS-131P_231P_431P_X31+_X31K, TS-X35, TS-X31X, TS-X31P2, TS-X31P3, QMiroPlus, Mustang-200.
[Important Notes]
[New Features]
Desktop
- QTS now supports Desktop Notice Board, which provides notifications for various events and announcements.
Control Panel
- QTS now supports TLS 1.3 for HTTPS secure connection.
- Users can now import custom root certificates to certify the SSL certificate of a server that the NAS needs to access.
- Users can now configure reverse proxy rules to hide the sensitive information on the server from clients and to enhance the security of data transmission over the network.
Firmware
- Updated OpenSSL to 1.1.1.
Storage
- Improved SSD cache design to enhance storage performance. Existing SSD cache will be automatically converted to the new design after QTS update to 5.0.0.
- Users can now use exFAT on x86 NAS models without purchasing an exFAT license.
- To enhance storage performance and data security, a RAID group now only supports a maximum of 16 disks.
QuFTP Service
- Added support for QuFTP Service, which allows users to configure and manage various FTP settings.
File Station
- File Station now supports displaying thumbnail previews for PDF files.
- Users can now choose to keep file attributes for files uploaded to File Station via SMB.
- Network & Virtual Switch now supports the DDNS service "DDNS Now".
- Added support for Forward Error Correction (FEC) for error detection and error correction in data transmission over unreliable or noisy communication channels.
QVPN Service
- QVPN now supports WireGuard.
NVS
- Starting from QTS 5.0.0, Advanced Network Driver is no longer a built-in component. Nevertheless, QTS automatically downloads the driver if the NAS is connected to the Internet. To install the driver, go to Network & Virtual Switch and follow the on-screen instructions. You can also manually download the driver from the QNAP website.
- Added support for the Intel E810 network adapter and for switching between the following modes: 4x25GbE, 2x25GbE + 2x25GbE, 4x10GbE + 4x10GbE, and 100GbE + 100GbE.
App Center
- QTS administrators can now purchase app licenses in the App Center.
- Added support for purchasing and activating licenses in the App Center.
iSCSI&FC
- iSCSI target service binding now supports all types of network portals.
[Enhancements]
Control Panel
- Added the option to enable or disable strong cipher suites.
- Added an option to choose whether to redirect users to the NAS login screen when connecting to the NAS IP address without the system port. To enhance device security, this option is disabled by default.
- To enhance device security, UPnP Discovery Service is now disabled by default.
- Added support for Content Security Policy HTTP header.
- QTS now enables the default "admin" account and resets its password when users press the Reset button on the NAS for three seconds. Nevertheless, to ensure device security, we recommend disabling the "admin" account and using a new administrator account after you finish resetting the system.
- Users in the administrator group now have read/write access permissions for default shared folders, except the "homes" shared folder.
- Users can now manually specify the time interval and the maximum number of failed login attempts in Control Panel to further enhance NAS security.
- WebDAV settings are now located in Control Panel > Network & File Services > Win/Mac/NFS/WebDAV. Users can now access the NAS root path by using a dedicated port number for WebDAV service.
- Users can now use port 443 for Let's Encrypt domain validation challenges.
- Shortened the default interval of automatic synchronization with the time server from 7 days to 1 day.
- Added support for setting user/group storage space quota up to 128TB.
Qsync Central
- Qsync Central is not pre-installed in QTS. Users can install this application in the App Center.
QuLog Center
- Improved the user interface of Advanced Search in QuLog Center.
- Added support for displaying the total connection time of online users.
- QuLog Center now displays computer names and accessed resources in System Access Log and Online Users.
Security
- To ensure device security, QTS now displays a message to remind users to disable the default "admin" account and to create another administrator account.
- QTS now displays a message to remind users to enable 2-step verification to ensure account security.
Mustang User driver
- Added support for Mustang User Driver 3.1.2.
Web Initialization
- QTS Smart Installation Guide now requires users to create a new administrator account. The default "admin" account is disabled after initialization.
Local display Initialization
- To ensure device security, QTS now reminds users to disable the default "admin" account and to create another administrator account during HDMI Installation.
Storage&Snapshots
- Storage & Snapshots now displays NAS model pictures in a new style.
- Users can now enable guaranteed snapshot space during storage pool creation and set a snapshot schedule during volume creation.
Desktop
- Added a notification message that reminds users to install Multimedia Console to enable media features.
- Added support for removing certain notifications from the Notice Board.
- QTS now enables dynamic wallpapers by default.
Storage
- Utilization charts in Storage & Snapshots are now located in Pool/Volume/LUN Management for better usability.
- Added support for Seagate IronWolf Health Management 1.3.12, which supports more Seagate IronWolf drive models.
File Station
- Modified the naming rules for duplicate folders to enhance usability.
- Added search tips and timeout messages in File Station in the event of searching through a large amount of data.
Samba
- Updated the SAMBA version to 4.13.
[Fixed Issues]
- QTS would display an incorrect warning message about connection failure after users added the default gateway to a virtual switch and then restarted the NAS.
- QTS displayed several incorrect Korean strings in various places.
- System Logs in QuFTP Service would always display 50 items per page even if users chose to display more items.
- Qfile would not display the current task progress when copying, moving, compressing, or deleting files.
- The NAS could not detect SSDs installed on the QDA-U2MP after firmware update to QTS 5.0.0.
- Network & Virtual Switch could not update DynDNS after users added DynDNS as a DDNS service.
- SNMP service would sometimes stop working when users monitored OIDs via SyncroMSP.
[Known Issues]
- Twonky Server cannot function normally on the TS-h973AX running QTS 5.0.0.1776.
- Cinema28 cannot display the media list.
- Some applications cannot access the NAS when secure connection and TLS 1.3 are enabled. This is due to a known issue in the applications. We will fix this issue in upcoming app releases.
- QTS 5.0.0 temporarily does not support certain file systems on external storage devices. To work around this issue, users can use HBS3 to back up files to external storage devices. Note that this workaround may require more CPU resources and increase backup task duration. We will soon fix this issue in an upcoming release.
- macOS Finder takes a long time to display content in SMB shared folders when users connect the Mac to the NAS via Thunderbolt. This problem may be due to Mac device driver issues. It only occurs to Mac devices with Intel processors and macOS 11.3 (or later versions).
- Thunderbolt write speeds are lower than expected in QTS 5.0.0.
- QTS and QuTS hero with newer kernel versions do not support ATTO Fibre Channel adapters. If you have already installed an ATTO Fibre Channel adapter on your device, we do not recommend updating the firmware to QTS 5.0.0 or QuTS hero h5.0.0 for the time being.
- QTS 5.0.0 temporarily does not support certain third-party applications, utilities, or services.
- QRM+ temporarily does not support the TS-x32, TS-x32U and TS-x35A models running QTS 5.0.0. We will add support for these models in upcoming releases.
- SNMP receivers cannot receive SNMP traps sent from ARM-based NAS models.
- Users cannot update the firmware of the QXG-10G2T-NXE network expansion card after updating QTS to 5.0.0.
- Network & Virtual Switch displays unexpected interface connection status and FEC status when users connect the following pairs of devices:
* NAS with Mellanox network adapter + NAS with Mellanox network adapter
* NAS with Intel E810 network adapter + NAS with Mellanox network adapter
* NAS with Intel E810 network adapter + Mellanox switch
* NAS with Mellanox network adapter + QSW-M5216 switch
* NAS with Intel 810 network adapter + QSW-M5216 switch
[Other Changes]
SSD Profiling Tool
- QTS no longer pre-installs SSD Profiling Tool by default. Users can install this tool in the App Center.
Control Panel
- Removed support for USB printers.
- Replaced SQL Server with MariaDB 5/MariaDB 10, which can be installed in the App Center.
- Removed iSCSI Service from Service Binding in Control Panel. Users can now configure iSCSI service binding settings in iSCSI & Fibre Channel.
Qboost
- Qboost is no longer a built-in application of QTS. Users can choose to install Qboost in App Center.
App Center
- To ensure system security, QTS now automatically disables applications that are not updated and that do not meet the minimum version requirements.
- Removed support for the following applications, utilities, or services:
* WebERP
* GLPI
* Vtiger CRM
* Ragic Cloud DB
QVR Pro Client & QVR Smart Client
- Starting from QTS 5.0.0, HybridDesk Station no longer supports QVR Pro Client (HDMI output). You can install QVR Smart Client on HybridDesk Station as the client software for your QVR Pro, QVR Elite, or QVP surveillance servers. Note that QVR AI Pack License is required for using QVR Smart Client. You can continue using QVR Pro Client on Windows or macOS as the client software for your surveillance servers to watch live views or play back recordings.
NVR Storage Expansion
- Starting from QTS 5.0.0, NVR Storage Expansion is no longer supported.
SONNY
#314 Message par SONNY »
Salut,je sais pas si cela a un rapport avec des mises à jours, mais depuis quelques temps lorsque je veux aller sur le forum,
mon navigateur me marque site dangereux etc,
bon du coup c'est pas grave je continue quand même puisque que je connais mais je préfère juste t'avertir ;)
#315 Message par flacon030 »
Oui j'ai un problème avec les redirection DNS, je m'en sort pas avec le HTTP et le HTTPS et les certificats et la configuration du NAS
Je patauge et je n'arrive pas a comprendre comment faire une redirection avec le nom de domaine que j'ai acheter sur 1&1
on arrive a se connecter en HTTPS mais il y a ce message d'erreur
en http cela fonctionne comme il faut...
Je désespère de trouver une solution, cela plus de 6 mois que je cherche
c'est la même chose avec le VPN sur mon routeur je ne trouve pas de solutions pour l'installer
il faudrait que je trouve une personne qui puisse me donner un coup de mains...
