#256 Message par flacon030 »
Mise a jour du qnap
TS-469 Pro/TS-469L
4.1.2 build 1229 181 MB 2014/12/29
Remarque :QTS4.1.2
[Enhancements and New Features]
[Antivirus]
- Updated the ClamAV engine to version 0.98.
[App Center]
- Administrators can choose to show app icons on the main menu for all users and the login screen in the App Center.
[Backup Station]
- Adds a detailed error message for unsuccessful host connection tests in Rsync.
- Adds the option to not execute backup jobs immediately.
[Cloud Backup]
- Adds Elephant Drive v2.8 support.
[File Station]
- Adds the thumbnail generation option to File Station.
- Adds support for subtitles in Video Station and File Station.
- Adds seeking support in video playback during on-the-fly transcoding (CodexPack v2.0 or above in HD Station is required for the TS-x70, TS-x79 and TS-x80).
- Users can switch resolutions in video playback without restarting video playback.
- Adds slideshow playback support in Media Viewer when users view photos.
- Adds an option for administrators to allows users to create shared links in File Station ("File Station" > "Options").
- Adds support for subtitles in File Station.
[Firmware Update]
- Adds support for patch updates in Live Update and the installed Qfix list in Firmware Update.
- Shows firmware change log before starting the firmware update.
- Shows new features added after firmware update.
[HD Station]
- Adds a "Restart" button in HD Station.
[Network Services]
- Adds an option to disable guest access in Folder Aggregation (users must log in before accessing the portal folder.)
[Qsync]
- Improved the Qsync folder sync performance.
- Users can create team folders in "Qsync" > "Team Folder" on the Turbo NAS.
[Photo Station]
- Users can choose to download slideshow photos in either their original resolution or resized (lower resolution.)
[Privilege Settings]
- User accounts can be disabled by the logged in administrator.
- Adds the permission type "No Access" to shared folders in Privilege Settings (displayed when folder privileges "RO" and "RW" and "Deny" are all unchecked.)
[SNMP]
- Allows the dash (-) and underscore (_) characters in SNMP community names.
[Security]
- Upgraded OpenSSL to version 1.0.1j.
- Upgraded wget to version 1.16.
[Storage Manager]
- Improved iSCSI and system stability.
- Adds block-based LUN support for LUN backup. (For SMB firmware, TS-x51, x53, x69, x70, x79, x80, IS-400.)
- Adds support for multiple RAIDs in a storage pool (For TS-x51/x53 models only.)
- The system can now recognize SSD drives by their serial number.
- Adds support for creating file-based iSCSI LUNs on x79U models.
- Allows copying an iSCSI IQN from the Turbo NAS UI.
- When creating thick volumes or performing instant iSCSI allocation, the system will automatically check if the volume has exceeded the storage pool alert threshold (For SMB firmware, TS-x51, x53, x69, x70, x79, x80, IS-400.)
- Displays shared folders located on virtual disks in File Station.
[Video Station]
- Adds support for subtitles in Video Station.
[VPN Service]
- Adds support for PPTP and OpenVPN VPN clients (Turbo NAS can act as a VPN client.)
[Misc]
- Displays the Chinese name for all major QNAP stations when users switch the QTS language to Chinese.
- Adds support for the photo wall and public app links for all Turbo NAS models.
- Improved Web Server response time.
[Changes]
[Power]
- The WOL option is now enabled by default.
[Remote Replication]
- Removed host connection mode in the RTRR job property.
[System Log and Syslog]
- Changed the log type of the "sync failed with NTP server" message to a warning.
[Misc]
- Amended Russian time zones.
[Bug fixes]
- The maximum volume capacity for online RAID capacity expansion is only 16TB (for TS-x31 series.)
- The iSCSI service crashes during high IO load.
- If 8 REXP-1600Us are simultaneously connected to a TS-1679U and volume expansion is in progress, the system will hang during book-up.
- Advanced NTFS permissions fail when applied from a Windows client via Samba.
- Disabling the volume system cache will cause the file system to over-allocate blocks.
- The TS-469 Pro reboots after performing LUN backups using CIFS/SMB.
- When both the "Enable Advanced Folder Permissions" and "Enable Windows ACL support" options are checked, the USB shared folders will become inaccessible using Samba.
- Fails to back up the Q-RAID 1 volume to external devices.
- For firmware version 4.0.7, when "Live Update" and "App Update" are both running at the same time, the firmware update will fail.
- Cannot expand the RAID configuration to 6TB using superblock version 0.9.
- Only 8TB are detected from a linear disk volume created using two 6TB hard disk drives.
- Fails to upload new files using WebDAV.
- Fails to play .m4v files in File Station during on-the-fly transcoding.
- Numbers (iPad App) cannot detect excel files or folders that contain empty spaces using WebDAV.
- Fails to apply the updated NAS-NAS backup schedule settings after the destination NAS is powered down.
- It takes a very long time to move a large number of folders and files to another shared folder on the same NAS via File Station.
- Fails to detect the home folder using a web browser via FTP.
- The performance deteriorates after attempting the /sbin/vs_refresh command.
- The Video Station player fails to play .mov files using the on-the-fly transcoding option.
- The UI layout becomes inconsistent in different languages on the Remote Replication wizard page.
- Fails to set permissions for shared folders if they contain a large number of sub folders and files.
- Fails to disable or remove DeaDBeeF from HD Station
- The "Initialize LDAP database" string in LDAP Server remains in English after switching the QTS language to Chinese.
- Fails to display photos that have been edited using Lightroom 5.5 in Photo Station
- Fails to detect and log the HDD temperature when HDDs (on REXP) are overheated and shutdown.
- Fails to filter and detect HTML tags in playlist names in Music Station
- If the group name exceeds 50 characters, the users from that group will fail to launch File Station.
- After a system reboot, a modified USB external storage configuration will be reset to default.
- Syslogs Server fails to display logs if they are too long.
- After logging into Photo Station using the following URL (xx.xx.xx.xx/photo) and enlarging the browser page to larger than 175%, the browser cannot switch to the second page if there are more than 60 photos in total.
- Fails to display Chinese folder or file names correctly if the NAS is accessed using a Mac via WebDAV.
- Guests cannot download photos from a public, shared album (a 401 unauthorized error message will appear.)
- When uploading a large number of files to an iSCSI volume, the iSCSI connection will fail.
- The NAS will reboot automatically after large files (larger than 850G) are removed in File Station.
- The time on the QTS desktop freezes after the user-defined daylight saving time.
- The system fails to wake from S3 sleep mode.
- The Check File System function fails after CloudLink is installed.
- The title bar of the QTS window will disappear if the Turbo NAS is configured for a specific time zone (GMT+1)
battaju
type véhicules : fiesta XR2I
#257 Message par battaju »
Desolé mais pour moi le problème reste le même.
#258 Message par flacon030 »
oui cette mise a jour concerne le serveur ou se trouve le forum, et non le forum en lui même.
Je cherche toujours d'ou viens l'erreur mais c'est compliqué pour moi car je n'arrive pas a reproduire le phénomène chez moi
#259 Message par flacon030 »
Mise a jour de tapatalk en version 4.7.0 qui devrait aussi résoudre les problème MSQL quant certains d'entre vous font une réponse sur un post existant
Added function to activate forum accounts via SSO
New and improved Smart Banner design
Admin CP SSO Settings merged. (Combined "Native Registration and Social Sign On (Recommended)" and "Native Registration Only" sections to single "In-App Registration" section)
Added function to auto set forum api key
Optimized push code
Other minor bug fixes
Fixed an XSS issue on the welcome screen
cosworth t35
#260 Message par cosworth t35 »
bonjour ,pour moi sa fonctionne "banane" "fou" "dieu"
#261 Message par flacon030 »
cosworth t35 a écrit :bonjour ,pour moi sa fonctionne "banane" "fou" "dieu"
merci pour ce retour positif
#262 Message par flacon030 »
Mise a jour du serveur
QTS4.1.3 Build 0217
[Enhancement]
- Added support for NAS installation over HDMI.*
- Enhanced NTFS and HFS+ external drive compatibility.
[Bug Fixes]
- Fixed the "Potential Remote-code Execution Flaw in GNU C Library (glibc)" (CVE-2015-0235) issue for the TS-x31, TS-x31+,TS-x39, TS-x59, TS-x51, and TS-x53 series.
- Fixed the Network Time Protocol Daemon vulnerability that could lead to unauthorized execution of arbitrary codes by remote users with admin privileges or triggering unintended changes on the system. (CVE-2014-9295, CVE-2014-9296)
- Fixed the ProFTPD vulnerability which could lead to unauthorized file ownership modification, directory operations, symlink creation and file timestamp modification and denial of services. (CVE-2012-6095, CVE-2011-1137, CVE-2010-4652, CVE-2010-4221, CVE-2010-3867)
- The system fails to synchronize the time on the QTS desktop and system time after the Turbo NAS is idle for over 20 minutes.
- When both the "Enable Advanced Folder Permissions" and "Enable Windows ACL support" options are checked, shared folders will become inaccessible using Samba.
- The TS-870 fails to mount volumes after upgrading to firmware version 4.1.2 20150126.
- System migration fails during a firmware update.
- The system is unable to upload documents with an Arabic name using File Station or via Samba.
- The system fails to stop the file uploading process when the storage quota is exceeded.
- USB devices can still be browsed and accessed after they are encrypted.
- The system fails to display subfolders (under shared folders) if accessed through a shared link.
- Shared folders cannot be browsed via AFP.
- Shared folders on the NAS (a domain member) cannot be accessed.
- The system fails to enforce read-only permissions on the @Recycle folder.
- Microsoft ODX fails after updating the firmware to 4.1.1 and later versions.
- The system fails to restore a LUN if the LUN list is empty.
- After a LUN backup job is deleted, the [Action] button becomes disabled.
- The system fails to back up large LUNs.
- Cloning VM images from the host to an iSCSI disk (using Block-based LUN, Thin Provisioning datastore) will cause the Turbo NAS to reboot.
- HD Station crashes after changing the external disk label.
- Severe latency when playing MP4 files using the DLNA player.
battaju
#263 Message par battaju »
..compris.. "banane"
#264 Message par flacon030 »
c'est normale ..Mgreen..
en gros se sont surtout des mises a jour du serveur pour des bugs de fonctionnement, des failles de sécurité, et quelques nouveautés
Mais pour le forum c'est transparent
Dans les prochains jours il faudra que je fasse une mise a jour du forum, et la il risque d’être impacté
Mais je vous préviendrais
battaju
#265 Message par battaju »
OK, merci pour l'information. ;)
#266 Message par flacon030 »
Mise a jour de PHPBB3
Je suis passé de la version 3.0.12 a la version 3.0.14
Non sans mal, la mise a jour automatique n'a pas fonctionné, j'ai du me modifier pas moins de 150 fichiers a la mains.
Cela semble fonctionner, mais surtout si vous voyer des problèmes n’hésitez pas a me le dire.
Bon j'ai enfin réussi a faire fonctionner le mise a jour automatique
il y avait quelques petits bug qui en principe ont été corrigé
Reste a voir comment cela fonctionne dans les prochains jours
J'ai du refaire une petite modification du fichier coulor.css, si vous avez des problèmes de couleur, vider les caches de votre navigateur et tous devrait renter dans l'ordre
#267 Message par flacon030 »
Depuis le passage de la version 3.012 vers la version 3.014 la fonction de fichiers joint ne fonctionne plus.
Je recherche pourquoi.
Cela impacte aussi tapatlk pour l'envoi de photos sans passer par tapatalk
#268 Message par flacon030 »
Voila le problème semble enfin réglé
Tous devrait fonctionner comme il faut a présent
N’hésitez pas a me faire parvenir tous défaut du forum
J'en ai profité pour que le logo online soit au dessus de l'avatar en non en dessous comme ici
cosworth t35
#269 Message par cosworth t35 »
Génial sa fonctionne quand on est un génie d'informatique tout se résout ..cartonnes.. ..classe..
#270 Message par flacon030 »
non sans mal
Je viens de trouver encore un petit défaut...
Mais rien de bien méchant, c'est a présent réglé.
