SONNY
#316 Message par SONNY »
C'est pas dramatique :| , malheureusement je n'y connais rien et je connais personne qui pourrai te renseigner :cry:
#317 Message par flacon030 »
Je finirais par trouver...
Merci pour l'avoir signaler
SONNY
#318 Message par SONNY »
Oui j'en suis sûr ;)
surtout un grand ..merci.. à toi "dieu"
#319 Message par flacon030 »
Bonjour
Je viens de mettre a jour le forum en version 3.3.5, la dernière a ce jour
#320 Message par flacon030 »
Je viens aussi de mettre a jour le serveur
QTS 4.5.4.1892 build 20211223
[Important Notes]
- For the status of QTS updates and maintenance for your NAS model, visit https://www.qnap.com/en/product/eol.php
- To learn more about NAS models that support the TL-D800C, TL-R1200C-RP, TL-D400S, TL-D800S, TL-D1600S, TL-R400S, TL-R1200S-RP, see the Compatibility List at https://www.qnap.com/en/compatibility-expansion
- We have fixed the vulnerabilities in the following apps to ensure your data security: Qsync Central and IFTTT Agent. To continue using these apps, go to the App Center and update them to the latest version.
- For more information on the kernel versions for NAS models that QTS 4.5.4 supports, see https://www.qnap.com/en/release-note/kernel
- Removed the following applications from App Center due to PHP 7 updates in QTS 4.4.1: phpEasyProject, Dolphin, CMS Made Simple, Vtiger CRM, iStat, and ownCloud.
- Due to compatibility issues, the following applications have been removed from the App Center in QTS 4.4.1: FileFlex, MantisBT, SugarCRM, Xeams, DokuWiki, and Azure Storage.
- Once you update QTS to 4.4.1 (or later) on the TS-1635AX, you will not be able to downgrade QTS to versions earlier than 4.4.1.
- Removed support for Plex Home Theater from HybridDesk Station.
- After reaching their end of support in July 2020, Notes Station and Qnotes have been removed from QTS App Center, Google Play, and Apple App Store. We recommend using Notes Station 3 and Qnotes 3 to benefit from the next-generation note-taking features. For details on how to transfer your notes from Notes Station 2 to Notes Station 3, see the following tutorial: https://www.qnap.com/en/how-to/tutorial ... -station-3
- Removed HappyGet from the App Center due to changes in Google extension policies.
- Starting from 4.5.1, QTS is no longer compatible with the following applications: DJ2 Console, CodexPack.
- QTS 4.5.4 does not support earlier versions of QVR Client. After updating QTS to 4.5.4 (or later), Surveillance Station users can download and install the latest version of QVR Client from the QNAP website: https://www.qnap.com/en/utilities/surveillance
[Security Updates]
- Fixed a security issue.
[Fixed Issues]
- Thunderbolt connection between the NAS and Mac would be interrupted after Mac woke from sleep mode.
- Users could not create a port trunking group on the TS-251D.
- Users could not create a VJBOD disk from a remote NAS running QTS 4.5.4.
- QTS would block WebDAV client IP addresses if users tried to access home folders via WebDAV.
- Users occasionally could not transfer files to WORM (Write Once, Read Many) shared folders.
- QTS would occasionally stop responding when users updated the firmware.
- File Station could not sort certain folder names in ascending order.
- Users could not use the same port number for both the source and the destination when configuring reverse proxy rules.
- Users could not find the "@Recently-Snapshot" folder when accessing shared folders via Samba.
- Users could not create Snapshot Replica jobs if SSH was not enabled on the source NAS.
- Users could not use the TCP port 443 for web service if the UDP port 443 was reserved for another service. (Normally, users should be able to use the same port number for both TCP and UDP without conflicts.)
- Connected external devices would automatically disconnect from the NAS after a long idle time.
- Users sometimes could not finish updating the virus definitions from ClamAV (Clam Antivirus).
- Antivirus reports could not correctly display file names or job names if antivirus job names in QTS contained Japanese characters.
- QTS could not remember the custom destination for antivirus archive files if the specified folder path contained a whitespace.
- Users could not connect to a proxy server if the proxy password contained the following special characters: % & + ;
- Users could not save a large Autodesk Revit project file in a mounted shared folder even though the NAS still had sufficient storage space.
- When users mounted NAS iSCSI LUNs on their Mac using globalSAN and then expanded the LUN capacity on the NAS, Mac would still display the original capacity.
- The TS-873A could not detect Disk 5 - Disk 8 on the TL-D800S expansion enclosure when the QXG-2G2T-I225 network expansion card was installed on the NAS.
- On the TS-h1886XU, after SSD overheating, fan speeds would not slow down even after SSDs cooled down.
- Fixed multiple security issues (CVE-2020-25684, CVE-2020-25685, and CVE-2020-25686).
- Users could not import large-capacity iSCSI LUNs.
- Storage & Snapshots would still display successful test results for Snapshot Replica jobs even if 2-step verification was enabled on the destination NAS. (Note: Snapshot Replica does not support 2-step verification).
- SNMP service would sometimes stop working when users monitored OIDs via SyncroMSP.
- On the TS-x31P models, users could not query CPU usage or CPU temperatures via SNMP.
- Domain users could not access NAS shared folders via WebDAV.
- On the NAS models that support a maximum of 16 snapshots per volume or LUN, users could not apply snapshot settings when Smart Versioning was selected as the snapshot retention policy.
- After setting up a NAS as the main domain controller and another NAS as the additional domain controller, domain users would take a long time to log in to the main domain controller when the additional controller was offline (for example, when this device was restarting).
- If users accessed QTS via an Smart URL and created share links in File Station, other users would not be able to access these share links.
- File Station would display an unexpected error message after users deleted a file from advanced search results.
- Users could not download files from shared folders if they manually specified folder paths and enabled advanced folder permissions.
- The domain machine account passwords in SMB could not be automatically updated.
- QTS would display an incorrect warning message about connection failure after users added the default gateway to a virtual switch and then restarted the NAS.
#321 Message par flacon030 »
Je viens enfin de prendre le temps de passer le forum de la version 3.3.5 en version 3.3.8
Tous semble fonctionner
N’hésitez pas a signaler tous dysfonctionnement
#322 Message par flacon030 »
Mise a jour du serveur
QTS 5.0.0.2055 build 20220531
[Applicable Models]
- HS-251+,S2
- QMiroPlus-201W
- Mustang-F100,Mustang-V100,Mustang-200-i7-1T-32G-R10,Mustang-200-i5-1T-32G-R10,Mustang-200-C-8G-R10,Mustang-200
- QBoat Sunny
- QGD-1600P,QGD-1600Pv0
- QGD-1602P
- QGD-3014-16PT
- TS-453S Pro,TS-853S Pro
- TS-531P
- TS-216,TS-416
- TS-128A,TS-228A,TS-212P3,TS-130,D1 Rev-B
- TS-231P3,TS-431P3
- TS-231P2,TS-431P2
- TS-831X,TS-531X,TS-431X,TS-431X2,TS-431X3,TS-431KX
- TS-431XU,TS-831XU,TS-1231XU,TS-431XU-RP,TS-831XU-RP,TS-1231XU-RP,TS-431XeU
- TS-932X,TS-832X,TS-332X,TS-532X,TS-932PX,TS-832PX
- TS-432XU-RP,TS-432XU,TS-832XU-RP,TS-832XU,TS-1232XU-RP,TS-1232XU,TS-432PXU,TS-432PXU-RP,TS-832PXU,TS-832PXU-RP,TS-1232PXU,TS-1232PXU-RP
- TS-133,TS-233,TS-433
- TS-1635
- TS-1635AX
- TS-435XeU
- TS-231+,TS-431+,TS-131P,TS-231P,TS-431P,TS-131K,TS-231K,TS-431K,D2,D4,D4 Rev-B
- TS-251,TS-451,TS-651,TS-851,TS-451S,TS-251+,TS-451+,TS-351,D2 Pro Rev-B,D4 Pro Rev-B
- TS-251A,TS-451A,D2 Pro,D4 Pro
- TS-251B
- TS-451DeU,TS-453DU,TS-453DU-RP,TS-853DU-RP,TS-1253DU-RP
- TS-451U
- TS-253 Pro,TS-453 Pro,TS-653 Pro,TS-853 Pro,TS-453mini,IS-453S
- TS-453Bmini,TS-253B,TS-453B,TS-653B,TS-453BT3,TS-253Be,TS-453Be
- TS-853BU,TS-853BU-RP,TS-1253BU,TS-1253BU-RP,TS-453BU,TS-453BU-RP
- HS-453DX,TBS-453DX,TS-251D,TS-253D,TS-653D,TS-453D,TS-451D,TS-453Dmini,TS-451D2
- TBS-453A,TS-253A,TS-453A,TS-653A,TS-853A,D6 Pro,D8 Pro
- TS-453U,TS-853U,TS-1253U,TS-453U-RP,TS-853U-RP,TS-1253U-RP,R4
- TVS-463,TVS-663,TVS-863,TVS-863+,TS-563,TS-963X,TS-963N
- TS-463U,TS-463U-RP,TS-863U,TS-863U-RP,TS-1263U,TS-1263U-RP,TS-463XU,TS-463XU-RP,TS-863XU,TS-863XU-RP,TS-1263XU,TS-1263XU-RP
- TS-564,HS-264,TBS-464,TS-262C,TS-462C,TS-264C,TS-464C,TS-364,TS-464,TS-664
- TS-464U,TS-464U-RP,TS-1264U-RP,TS-464eU,TS-864eU,TS-864eU-RP
- TVS-471,TVS-671,TVS-871,TVS-871T
- TVS-871U-RP,TVS-1271U-RP,TVS-471U-RP,TVS-471U,R8
- TVS-472XT,TVS-672XT,TVS-872XT,TVS-672N,TVS-872N,TVS-872X,TVS-672X,TVS-472X
- TVS-872XU,TVS-872XU-RP,TVS-1272XU-RP,TVS-1672XU-RP,TVS-2472XU-RP,TVS-972XU,TVS-972XU-RP
- TVS-473,TVS-673,TVS-873,TVS-473e,TVS-673e,TVS-873e
- TS-h973AX,TS-473A,TS-673A,TS-873A
- TS-873AU,TS-873AU-RP,TS-1273AU-RP,TS-1673AU-RP,TS-873AeU,TS-873AeU-RP
- TS-873U,TS-1273U,TS-1673U,TS-873U-RP,TS-1273U-RP,TS-1673U-RP
- TVS-675
- TVS-h875U,TVS-h875U-RP,TVS-h1275U-RP,TVS-h1675U-RP
- TS-1277,TS-877,TS-677,TS-1677X
- TS-877XU,TS-877XU-RP,TS-1277XU-RP,TS-1677XU-RP,TS-2477XU-RP,TS-977XU-RP,TS-977XU,TS-h1277XU-RP,TS-h977XU-RP,TS-h1677XU-RP,TS-h2477XU-RP
- TS-EC880 Pro,TS-EC1080 Pro,TVS-EC880,TVS-EC1080,TVS-EC1080+
- TS-EC880U,TS-EC1280U,TS-EC1680U,TS-EC2480U R2,TVS-EC1280U-SAS-RP R2,TVS-EC1580MU-SAS-RP R2,TVS-EC1680U-SAS-RP R2,TVS-EC2480U-SAS-RP R2,TS-EC2480U,TS-EC880U R2,TS-EC1280U R2,TS-EC1680U R2,TVS-EC1280U-SAS-RP,TVS-EC1580MU-SAS-RP,TVS-EC1680U-SAS-RP,TVS-EC2480U-SAS-RP,R12,R16,R24
- TVS-882T,TVS-1282T,TVS-682,TVS-882,TVS-1282,TVS-682T,TVS-1282T3,TVS-882BR,TVS-882BRT3
- TVS-882ST,TVS-882ST3
- TVS-1582TU
- TS-883XU,TS-883XU-RP,TS-1283XU-RP,TS-1683XU-RP,TS-983XU,TS-983XU-RP,TS-2483XU-RP,TS-h1283XU-RP,TS-h2483XU-RP,TS-h1683XU-RP
- TS-1685,TS-h886,TS-h686
- TES-3085U,TES-1885U,TS-1886XU-RP,TS-h1886XU-RP,TS-h1886XU-RP R2
- TS-2888X,TVS-h1688X,TVS-h1288X
- TS-h3088XU-RP
- TDS-16489U
- TS-h2490FU
- TS-328,TS-428,TS-230,D2 Rev-B
- TS-551
- TS-473,TS-673,TS-873
- TVS-951X,TVS-951N
- GM-1000,TNS-h1083X,TNS-h1083X (A Side),TNS-h1083X (B Side)
- TS-i410X
[Important Notes]
- After firmware updates to QTS 5.0.0, the following models cannot be downgraded to earlier QTS versions due to changes in software compatibility: TS-131K, TS-231K, TS-431K, TS-431XeU, TS-431X3, TS-231P3, and TS-431P3.
[Security Updates]
- Fixed the security issue CVE-2022-0778. For details, see https://www.qnap.com/en/security-advisory/qsa-22-06
- Fixed multiple security issues (CVE-2021-31439, CVE-2022-23121, CVE-2022-23123, CVE-2022-23122, CVE-2022-23125, CVE-2022-23124, and CVE-2022-0194). For details, see https://www.qnap.com/en/security-advisory/qsa-22-12
- Fixed security issues CVE-2022-22719, CVE-2022-22720, CVE-2022-22721, and CVE-2022-23943. For details, see https://www.qnap.com/en/security-advisory/qsa-22-11
- Applied multiple security updates to further enhance system security.
[Fixed Issues]
- NAS CPU usage and memory usage would increase significantly when running a backup job from the NAS to a TR-004 expansion enclosure whose file system was HFS+.
- The "hidden" file attribute would be disabled after users copied hidden files from Windows 10 to the NAS.
- File names would change after users copied files from the NAS to an external USB drive due to issues in HFS+ driver.
- On the TS-1886XU-RP, the system fans would stop if users chose to adjust the fan speeds according to the temperature threshold and if the system temperature was below the threshold.
- QTS would display unexpected error messages about DMC and GuC firmware on the TS-x64.
- QTS would sometimes display unexpected error messages about OpenSSL when users visited certain websites.
- Users could not obtain up-to-date volume information for created or removed volumes when querying SNMP OIDs.
- Feature description in "Control Panel" > "System" was not correctly translated into Simplified Chinese.
- Some LDAP domain users and domain groups would be missing after users restored an LDAP database to another NAS that had a different processor architecture.
- QTS would display a message that asked users to disable 2-step verification on the destination NAS of Snapshot Replica jobs even if 2-step verification was already disabled.
- Users could not perform DNS queries with IPv6 for the local device.
- Network & Virtual Switch could not display certain information when users selected a virtual switch as the system default gateway and disabled NCSI (Network Connectivity Status Indicator).
- Static Route would stop functioning after a network adapter was connected or disconnected.
- Network & Virtual Switch could not display correct information for network interfaces when users installed an external network adapter on a NAS model that supported USB QuickAccess.
- Certain users could not successfully update ClamAV virus definitions.
- Control Panel would display an unexpected user "browser-station" when importing users from another NAS where Browser Station was installed.
- In File Station, after uploading files via FTP, users could not delete these files from search results.
- In File Station, users could not delete a subfolder by right-clicking the subfolder on the left pane and then selecting "Delete".
- In File Station, after copying files from an external USB device, users could not delete these files from search results.
- The NAS would stop responding when users searched for a large number of UTF-8 files via SSH on an HFS+ external drive.
[Known Issues]
- macOS Finder takes a long time to display content in SMB shared folders when users connect the Mac to the NAS via Thunderbolt. This problem may be due to Mac device driver issues. It only occurs to Mac devices with Intel processors and macOS 11 (or later versions).
- Thunderbolt write speeds are lower than expected in QTS 5.0.0. Note: Due to Thunderbolt driver compatibility issues, if you are using macOS 11/12 devices with Intel processors, we do not recommend updating QTS to 5.0.0 for the time being.
- QTS and QuTS hero with newer kernel versions do not support ATTO Fibre Channel adapters. If you have already installed an ATTO Fibre Channel adapter on your device, we do not recommend updating the firmware to QTS 5.0.0 or QuTS hero h5.0.0 for the time being.
- Control Panel cannot display the information of the TPU installed in the M.2 slot on the QGD-1602P.
#323 Message par flacon030 »
il viens de passer de la version 3.3.8 a la version 3.3.10
Dite moi si vous rencontrez des problèmes
Bon surf
#324 Message par flacon030 »
Je viens de mettre a jour le serveur qnap
QTS 5.0.1.2277 build 20230112
[Applicable Models]
- HS-251+,S2
- QMiroPlus-201W
- QBoat Sunny
- QGD-1600P
- QGD-1602P
- QGD-3014-16PT
- TS-531P
- TS-216,TS-416
- TS-231P3,TS-431P3
- TS-231P2,TS-431P2
- TS-1635
- TS-1635AX
- TS-435XeU
- TS-251B
- TS-451U
- TS-453Bmini,TS-253B,TS-453B,TS-653B,TS-253Be,TS-453Be,TS-453BT3
- TS-564,HS-264,TBS-464,TS-262C,TS-462C,TS-264C,TS-464C,TS-364,TS-464,TS-664,TS-262,TS-462,TS-264
- TVS-672N,TVS-872N,TVS-872X,TVS-672X,TVS-472X,TVS-472XT,TVS-672XT,TVS-872XT
- TVS-675
- TVS-682,TVS-882,TVS-1282,TVS-882BR,TVS-882T,TVS-1282T,TVS-682T,TVS-1282T3,TVS-882BRT3
- TVS-1582TU
- TS-h3088XU-RP
- TDS-16489U
- TS-h2490FU,TS-h1090FU
- TS-551
- TVS-951X,TVS-951N
- TS-i410X, TS-410E
- TS-253E,TS-453E
- TS-h1290FX
- TS-h987XU-RP,TS-h1887XU-RP,TS-h2287XU-RP,TS-h3087XU-RP
- TVS-h474,TVS-h674,TVS-h874
- TS-1655
- TDS-h2489FU
[Security Updates]
- Fixed the security issue CVE-2022-27600.
[Fixed Issues]
- Fixed an issue where QTS might sometimes report abnormal fan speeds on the QM2 expansion card.
- Fixed an issue where QTS would occasionally keep displaying warnings about unclean file system after users restarted the NAS.
- Fixed an issue where the Overview section in Storage & Snapshots could not correctly display the status of SED drives.
- Fixed an issue where PHP did not support FreeType.
- Fixed an issue where after entering the auto-protection mode, the NAS could not restart when the UPS resumed power. (Note: If a UPS is set up, the NAS can enter the auto-protection mode in the event of a power outage. Normally, the NAS will restart when the UPS resumes power.)
- Fixed an issue where the system would create a duplicate snapshot schedule if users clicked the "Apply" button twice when editing a snapshot schedule.
- Fixed an issue where users could not take snapshots for a volume and the system would incorrectly indicate that the volume was in read-only or read/delete mode.
- Fixed an issue where the system generated dnsmasq logs whenever QVPN was connected or disconnected, causing insufficient space on the ram disk.
- Fixed an issue where users could not restore settings with a BIN file (binary file for backing up system settings) if the current firmware version was different from the firmware version in which the BIN file was generated.
- Fixed an issue where users could not access shared folders via WebDAV if another folder already existed in the specified path.
- Fixed an issue where File Station would display a preview window instead of directly downloading files when users tried to download files via a share link.
- Fixed an issue where users could not unlock an encrypted folder in File Station and the system might display an error message after a failed attempt.
[Known Issues]
- QTS and QuTS hero with newer kernel versions do not support ATTO Fibre Channel adapters. If you have already installed an ATTO Fibre Channel adapter on your device, we do not recommend updating the firmware to QTS 5.0.1 or QuTS hero h5.0.1 for the time being.
- Thunderbolt connection between the NAS and Mac sometimes cannot automatically resume after users restart the NAS.
- Network connection issues may occur when users add both 10 GbE ports of the QXG-10G2SF-CX4 network expansion card to a virtual switch.
SONNY
#325 Message par SONNY »
Salut,
un grand ..merci..
pour ma part rien de à signaler pour le moment 8)
nicosworth
#326 Message par nicosworth »
pour moi ça marche au top ;)
#327 Message par flacon030 »
Merci pour votre retour
#328 Message par flacon030 »
Encore une très grosse étape de passer
Je viens de changer de NAS
Je suis toujours chez Qnap, et cette fois ci avec le dernier 855
Plus de disque de puissance de RAM ect
Avec la fibre qui arrive cela va tous changer
https://www.qnap.com/fr-fr/product/ts-855x
SONNY
#329 Message par SONNY »
Je ne sais pas si il y a un rapport mais à chaque clic sur un sujet j'ai le message " votre connexion n'est pas privée "
#330 Message par flacon030 »
oui j'ai mon certificat let's encrypt pour les pages en https qui est périmé, du coup il y a ce message d'erreur
il faut que je voie comment le mettre a nouveau en place
cela risque de prendre quelques jours, désolé pour ce dérangement
