#271 Message par flacon030 »
Mise a jour du firmware du serveur
passage en 4.1.4
2015-06-01
4.1.4 build 0522
QTS4.1.4 Build 0522
[Enhancement]
- Updated the glibc x86_64 version from 2.11.1 to 2.19 and fixed the GHOST vulnerability (CVE-2015-0235.)
(Note: Due to changes in the x86_64 library, some apps (including Virtualization Station, aMule, DVBLink TV Server) may fail to start after patch application. If this is the case, please update the affected apps to their latest version in QNAP App Center.)
- All users can now upload to shared folders (right click on a folder in File Station > Share > Via Email > Allow file upload to this folder.)
[Bug fixes]
- Upgrading to firmware 4.1.3 increased fan speeds and fan noise (for TS-x79U-RP, TS-EC880U/1280U/1680U and SS-ECx79U-SAS-RP.)
- The system fails to display the desktop correctly after logging into QTS using Internet Explorer (on Windows 32-bit) and 360 Browser.
- SNMP Server cannot be enabled after establishing a PPTP VPN connection between the NAS and a PC.
- Port trunking settings are not retained after system migration.
- The system fails to copy files to the NAS from external devices using the HFS+ file system in File Station.
- The system fails to restrict playback to tagged photos in slideshow mode in Photo Station after filtering conditions are set.
- The system fails to display the graphic meters for CPU and memory the first time the Dashboard is opened with Chrome.
- Users are unable to retrieve a directory listing from the FTP Server with an FTP client.
- The system fails to back up LUNs (giving an error message: I/O error while copying the LUN data.)
- The system fails to finish a complete SMART test (for WD WD4001FYYG-01SL3.)
- The system fails to detect global spare drives after system migration.
#272 Message par flacon030 »
Mise a jour du forum
QTS4.1.4 build 0820
[Bug Fixes]
- Normal users cannot play transcoded videos in Private Collection in Video Station (only administrators can play them).
- When you disable LED lights, enter hibernation mode and then resume the system, the LED lights will still be enabled.
- If a USB device is connected and you upgrade to 4.1.4 build 0804 there is a chance that the system will not recognize the USB device.
- The TS-x79 series NAS does not support sleep mode. This option has been removed from these NAS models.
- Motion detection is not triggered in Surveillance Station on ARM-based NAS.
- Fails to connect to the NAS while uploading files in Photo Station 5.
- For some power supplies, the NAS reports a power supply error in the system logs.
- The TS-x31 series and TS-269H fail to use FTP via SSL/TLS.
[Enhancement]
- Allows showing notifications about QTS Beta firmware available in Live Update.
[Notice]
- We recommend that you upgrade the built-in PHP by downloading the PHP app 5.5.26 (or newer) from the App Center to address multiple vulnerabilities. Please follow the automatic notifications to ensure your PHP is always current.To ensure reliability, users should check for compatibility before upgrading.
- We recommend that you upgrade the built-in MySQL by downloading the QMariaDB app 5.5.44 (or newer) from the App Center to address multiple vulnerabilities. Please follow the automatic notifications to ensure your QMariaDB is always current. To ensure reliability, users should check for compatibility before upgrading.
#273 Message par flacon030 »
Mise a jour du serveur
Je viens de passer en version 4.2.0 beta
#274 Message par flacon030 »
Le serveur est a présent en version 4.2.0 version définitive
[Bug Fixes]
This release has corrected the following issues:
- When playing photos as a slideshow on a DLNA TV, Photo Station 5 will get stuck on a single photo.
- Qvideo for iOS fails to load .srt files.
- Qvideo for Android fails to load .srt files.
- Video Station fails to update movie information.
- The Episode Filter in Download Station cannot recognize Italian characters.
- The system incorrectly recognizes Traditional Chinese filenames if they are uploaded to the NAS (mapped as a FTP drive) using Windows File Explorer.
- The system fails to remove the .dsdownload filename extension once files have finished downloading.
- Photo Station fails to load Pixlr Editor.
- The system fails to activate EuP mode.
- The system fails to retain speed settings for system fans after the fan rotation speed is set to manual.
- The system fails to enter sleep mode.
[Known Issues]
For x39, x59, x69, x71, x79 and x80 series NAS with Intel network controllers i217, 82574, or 82579, the maximum MTU size of these LAN ports can only be set to 8996 (you may need to set the matching MTU size on the switch/router/client as necessary).
[Photo Station 5] Sharing to Weibo (a Chinese social media website) using the Upload function may be occasionally unsuccessful due to the website's network stability.
For enhanced security on access controls, myQNAPcloud employs the OAuth 2.0 authorization protocol. If you experience difficulties accessing myQNAPcloud using mobile or client utilities, please see the following FAQs:
Setting access controls to “Public” in order to use CloudLink on supported client devices: https://support.myqnapcloud.com/faq/_fa ... nk-service
More information regarding access modes: https://support.myqnapcloud.com/faq/_fa ... evice-mean
[TVS-871T] In certain circumstances (such as modifying the MTU size on the Mac), the Thunderbolt throughout performance may not be optimal.
#275 Message par flacon030 »
Mise a jour majeur du serveur en 4.2.1
Remarque :
QTS 4.2.1 Build 20160419
[New Feature]
QTS
QTS
- Added the Virtual Switch function to Network Manager.
- Added the "Overview" page for Internet topology settings.
Network & Virtual Switch
- Both the Virtual Switch application and QTS firmware do not support downgrading.
- The system cannot slow down network speeds when using a 10GbE or 40GbE Ethernet card or port trunking.
Notification
- Added Oauth 2.0 support for SMTP Gmail accounts ("Desktop" > "Options" > "E-mail Account").
App Center
- Improved the user interface.
- Apps from third-party sources can now be imported in the App Center ("App Center" > "Settings" > "App Repository")
Photo Station
- The aspect ratio of photo thumbnails in Photo Station can now be changed.
- Added third-party domain name support for sharing links in Photo Station.
VPN Server
- The NAS can now be set as both a PPTP and OpenVPN VPN server and client.
VPN Client
- Multiple PPTP and OpenVPN clients can now be added.
[Enhancement]
QTS-Misc
- Upgraded Unrar to v5.3.3, Zip to v3.0, and Unzip to v6.0
- Upgraded Netatalk to v3.0.8
- Added GMT-3:00 Greenland Standard Time and Nuuk (Godthab) time zones (in "Control Panel" > "System Settings" > "Time")
File Station
- In File Station, remote connection default settings have changed from administrator only to administration group only.
- Only administrators can permanently delete files from File Station. Files deleted by other users will be moved to the Trash.
OpenSSL
- OpenSSL has been updated to 1.0.0t/ 1.0.1r
[Change]
QTS-Misc
- Removed the DLNA Media Server option in Bonjour ("Service Discovery" > "Bonjour")
[Note]
Media Streaming Add-on
- When updating to QTS 4.2.1, the Media Streaming Add-on must be updated to version 421.0.1.0 (or newer).
[Bug Fixes]
QTS 4.2.1 Build 20151211
- Fixed an issue where the NAS would not accept a domain group's name if it contains special characters.
- Fixed an issue where email notifications would be disabled when using 2-step verification if there is no username & password set in the SMTP server.
- Fixed an issue where testing a RTRR job would fail when creating a job to backup files from local to remote via CIFS.
- Fixed an issue where the profile folder would have two IDs with the access right of 3000001 after the domain users setup profiles.
- Fixed an issue where after detaching a JBOD, its image in Storage Manager will remain in chassis view.
- Fixed an issue where after installing CloudLink and rebooting the NAS, the System Event Logs will display a "..file system is not clean.." message.
- Fixed an issue where the progress would be stuck at "0" when relaunching Storage Manager and entering "Storage Space" page when using Internet Explorer 11.
- Fixed an issue where after enabling advanced folder permissions in the Control Panel, File Station would show an error message in the right-panel Permission tab.
- Fixed an issue where File Station would show an error message when sharing files with more than one person and sending an email link via the NAS.
- If Windows ACL is enabled in the Closed Beta version, snapshots will not be displayed under "Properties" > "Previous Versions".
QTS 4.2.1 Build 20151224
- Fixed an issue where the UI may freeze when selecting "Win/Mac/NFS" in "Control Panel" > "Network Services".
- Fixed an issue where changes would not be applied when repeatedly modifying the LUN name in the iSCSI storage page in Launch Storage Manager.
- Fixed an issue where the user would fail to upload 2 folders to the NAS from a local PC when "Show files and folders of my PC" is enabled.
- Fixed an issue in Firefox where File Station would show incorrect messages when choosing to open video files using the "Open with VLC" option.
QTS 4.2.1 Build 20160201
- Fixed an issue where the Expand Capacity button will be enabled before changing any drive in Storage Manager.
- Fixed an issue where an increasing amount of system RAM will be displayed while copying a large number of small files to the NAS.
- Fixed an issue where the unallocated size will change after taking snapshots, copying some files, then rebooting the NAS.
- Fixed an issue where the content of encrypted folders are not included in snapshots.
- Fixed an issue where the system will fail to create a snapshot replica job to a remote NAS when there is a special character ')' in the password.
- Fixed an issue where there is nothing shown in Background Tasks after Snapshot Replica is executed.
- Fixed an issue where the system log shows "The file system is not clean...." when rebooting with various apps launched and RTRR in process.
- Fixed an issue where the Media Library would occasionally show incomplete file information when changing the iTunes media folder to the NAS multimedia folder.
- Fixed an issue where the WebDAV connection would fail after the HTTPS port is changed to 443.
- Fixed an issue where the content page of songs would be cleared when uploading specific MP3 files.
- Fixed an issue where the AFP connection would be interrupted when connecting through an encrypted folder.
- Fixed an issue where files would be incompletely moved when repeatedly moving files between a shared folder and an external folder in File Station.
- Fixed an issue where changing folder permissions would not take effect if changing the folder permissions from R/W to Read-only via Samba protocol.
- Fixed an issue where the connection would fail during backing up a VM image to an external device.
- Fixed an issue where an error message would appear when performing a RTRR task to backup files from local to remote and placing a folder to the source folder through SAMBA protocol.
- Fixed an issue where the total number of music in the Media Library would be incorrect when adding .cue, .flac, and MP3 files into a folder.
- Fixed an issue where the system would become unresponsive when uploading high-resolution pictures in Photo Station.
- Fixed an issue where an error message would appear after creating a backup job and selecting specific folders in the source and destination folder where the selected folders have a prefix "share" in the folder name.
- Fixed an issue where files in the root folder would become folders after cloning a Snapshot.
- Fixed an issue where the system would show a warning message when linking to an OpenVPN server.
- Fixed an issue where the log file would report incorrect information when swapping HDD locations in a NAS and removing the pool.
- Fixed an issue where the pool expansion operation would fail.
- Fixed an issue where the system would be unable to show a clear indication of the maximum volume size when creating volume with default settings.
- Fixed an issue where the volume resize operation would fail if the file system is not clean.
- Fixed an issue where background tasks would be stuck in a calculation step when uploading files to File Station using Firefox.
- Fixed an issue where the "copy the link" option cannot be selected in download operations when sharing files with share links with the Android browser.
- Fixed an issue where "Compression" in Backup settings would be unable to remain on the edit page when doing iSCSI Storage.
QTS 4.2.1 Build 20160311
- Fixed an issue where the QTS UI would get stuck on "Network" on a new NAS when migrating data from another NAS that used a complicated DDNS password (containing characters such as !=[].)
- Fixed an issue where Storage Manager would fail to restore a backup image file via CIFS on a NAS without storage pools.
- Fixed an issue where creating a download task by pasting a URL was not available in Download Station (click "+" > "Input URL") using Internet Explorer.
- Fixed an issue where the "sed: bad option in substitution expression" warning message would appear after using the phrase "backup" as the Time Machine password and restarting the NAS using the "/etc/init.d/atalk.sh restart" command in Putty.
- Fixed an issue where the NAS would occasionally fail to resolve a DNS name.
- Fixed an issue where switching between different pages on a shared link would be recognized as an error event and an error log would be generated in System Logs.
- Fixed an issue where users could not add shared folders as media folders in Multimedia Management.
- Fixed an issue where the shortcuts in Control Panel could not be dragged to the QTS Desktop as shortcut using Internet Explorer 11.
- Fixed an issue where, under certain conditions, TS-253A/453A/653A/853A NAS models may have unnecessary high-speed fan rotation.
- Fixed an issue where moving one subfolder to another subfolder in the same directory in File Station would fail.
- Fixed an issue where copying files over 30MB in size to OneDrive would fail when using a remote connection in File Station.
- Fixed an issue where the Media Player would fast forward an mp4 file during play in File Station if CodexPack is not installed.
- Fixed an issue where a newly-created shared folder would fail to be listed as the destination folder when backing up the domain controller database.
- Fixed an issue where the error message "/Public/Picture Format add to auto transcoding failed." would appear when setting up a folder as a media folder in File Station.
- Fixed an issue where the "Hit iSCSI LUN Threshold" log would appear in System Logs when copying a file to a LUN with an allocated size larger than the file.
- Fixed an issue where the log header was ambiguously defined as "REXP" (rather than a meaningful one as "Internal Cache") for mSATA or M.2 SSD.
- Fixed an issue where the last checked firmware update time under "Live Update" would be displayed using the current login time (rather than the time users last checked for an update).
- Fixed an issue where the scroll bar in Photo Station would get stuck at the bottom-right of the screen before the photos were loaded.
- Fixed multiple vulnerabilities in Standalone server of Microsoft Networking (Samba), collectively known as Badlock.
[Known issue]
- After completing the QTS update and before restarting the NAS, the first-time shutdown will be a restart instead. (For TS-X53A & TBS-453A series.)
- If you are using a NAS with multiple NICs and have one of the following firmware builds installed you must reset your network settings in QTS or change your network cable as the network mapping will mismatch. Firmware builds: 4.2.0 build 20160119, 4.2.0 build 20160130, 4.2.0 build 20160311.
[Note]
- After upgrading QTS to version 4.2.1, if the Snapshot feature is enabled, the system will automatically enable the storage pool threshold alert to efficiently conserve storage pool space. You can re-adjust the threshold value to avoid receiving system warnings, but it is strongly recommended to expand the storage capacity or to delete unnecessary snapshots.
- Some functions mentioned in the above fixed bug list may not exist in your model. For detailed software and hardware features, please visit the product page of the QNAP website.
#276 Message par flacon030 »
Pour votre service je viens de remplacer mon QNAP
Je suis passe au TVS-682
La mise a jour de l'OS a été fait aussi
Et franchement c'est une vrai tuerie, tous est instantané, c'est un vrai régale
2016-07-15
4.2.2 build 20160711
QTS 4.2.2 Build 20160711
[New feature]
Storage management
- VJBOD host functions are now supported by the x82 series (with firmware 4.2.2 or newer).
- NAS models that support Storage Pools and iSCSI service with firmware 4.2.1 (or newer) can be used as a remote NAS for VJBOD. Refer to the product specifications for details.
Audio Alert (models with speakers)
- Added Voice Alert.
Smart Fan(x82 only)
- Added separate fan controls for system and CPU.
Volume Control (models with speakers)
- Added volume control options in the QTS desktop toolbar (TBS-453A and TVS-x82 series).
Helpdesk
- Added Helpdesk.
File Station
- Added support for directly opening .eml files using QmailAgent in File Station.
Container Station
- Added bridge mode in Container Station (every container can have its own unique IP).
[Enhancement]
Virtualization Station 2.2
- Added support for automatically checking network connections and remote storage capacities of imported/exported VM in Virtualization Station.
[Known issue]
Back up
- The Container Station folder can only be backed up using Rsync when no containers are running. It is recommended to use the import/export feature in Container Station to back up containers.
Container Station
- Setup default folder of Contrainer Station on a VJBOD shared folder and reboot VJBOD would cause Container Station crash. Container Station v1.6 will not support VJBOD and filter out all VJBOD shared folders.
[Bug Fixes]
QTS
- Fixed an issue where a remote target would attempt to automatically reconnect after it was manually disconnected.
- Fixed an issue where the VJBOD reconnection process on the host NAS would be stuck when changing the administrator’s password on the remote NAS.
- Fixed an issue where a subfolder could not be opened and displayed in the folder tree in File Station after enabling “Advanced Folder Permissions” for the subfolder’s parent folder.
- Fixed an issue where the status column would be cut off from the UI in Network & Virtual Switch if the interface name is too long.
- Fixed an issue where an incorrect iSCSI connection type would be displayed after deleting a VJBOD from a remote NAS.
- Fixed an issue where a duplicate iSCSI connection would be displayed after mounting a LUN.
- Fixed an issue where the Shared Folder, Users, and HD Station pages could not be opened using their shortcuts on the QTS desktop after opening and minimizing the Control Panel window.
- Fixed an issue where a duplicate Trunking Group would be displayed after removing a Trunking Group.
- Fixed an issue where the system would fail to authenticate using CHAP authentication if the CHAP password contains non-alphanumerical characters.
- Fixed an issue where the system would still display the previous Trunking mode after changing the Trunking mode in Network & Virtual Switch.
- Fixed an issue where a Windows 10 VM would not start properly in Virtualization Station.
TVS-682/TVS-682T/TVS-882/TVS-882T/TVS-1282/TVS-1282T
cosworth t35
#277 Message par cosworth t35 »
Flacon ,tu es vraiment trop gentil avec nous, on n'est soigner au petit oignon avec toi ..cartonnes.. ..10.. ..merci..
#278 Message par flacon030 »
Je me fait plaisir par la même occasion
A présent je vais enfin pouvoir héberger mes vidéo et les mettre en ligne
#279 Message par flacon030 »
Je viens de mettre de la mémoire cache M2 de 256MO sur le serveur
Cela le rend en principe encore plus réactif
J'en ai profité pour faire une mise a jour mineur de l'OS
la version 4.3 est en beta et devrait bientôt arrivé
2016-12-15
4.2.2 build 20161214
QTS4.2
QTS 4.2.2 Build 20161214
[Bug fixes]
- Fixed an issue where bluetooth devices would not appear on the list of media streaming devices in Music Station on non-x86-based models.
- Fixed an issue where using myQNAPcloud service would make x86-based and ARM-based models unable to enter disk standy mode.
cosworth t35
#280 Message par cosworth t35 »
"dieu" ..10.. ..merci..
#281 Message par flacon030 »
QTS 4.2.3 build 20170121 for all model except TS-809 and TS-809U
( 2017/01/24 )
QTS4.2
QTS 4.2.3 Build 20170121
[Bug fixes]
- Fixed an issue where Qfinder could not display the direct link IP address of the second Mac when users connected two Macs to the NAS via Thunderbolt.
- Fixed an issue where users could not select pre-defined domain names when sharing files via emails or to social networking websites in Photo Station.
- Fixed an issue where administrators could not access the @Recycle folder via SMB after applying folder permission settings.
- Fixed an issue where the RTC (real-time clock) time would change after users enabled the NTP service and then restarted the NAS.
- Fixed an issue where File Station would display the string "online streaming" in Japanese when the system language was set to Korean.
- Fixed an issue where a dialog box that was expected to appear did not pop up when users performed "Replace Disks One by One" on a legacy volume in Storage Manager.
- Fixed an issue where all internal and external antivirus scan jobs would disappear from the scan job list when users attempted to scan external folders after unplugging external drives.
- Fixed an issue where users could not access Ubuntu 16.04 via the remote desktop URL in Linux Station.
- Fixed an issue where search results in File Station would not include files stored not in their owner's folders when users searched by file owners.
- Fixed an issue where users could not transfer multiple files via AFP due to splicing issues.
- Fixed heap overflow vulnerabilities.
- Fixed firmware update vulnerabilities. For more information, see solution NAS-201701-18 in QNAP Security Bulletins a
#282 Message par flacon030 »
QTS 4.3.3.00095 Build 20170217(Beta)
[New Feature]
- Added the Atmovies for Movie extension to provide an online movie database in Traditional Chinese.
- Added the ability to mount a remote QNAP NAS where 2-step verification is enabled.
- Changed the size of the reserved space for Media Library from 5% of the total storage space to 10 GB.
- Added support for external USB/SATA optical disc drives. File Station can now read optical discs used for data storage purposes. Note that this feature is not available on the TS-x10, TS-x12, TS-x19, TS-x20, TS-x21, and TS-x69 series.
- Added support for the QM2-2S series PCIe adapters.
- Added support for viewing the details of CPU usage, the status of processes, and the activity of storage pools in Resource Monitor.
- Added support for viewing and managing external devices in tree structures.
- Added the option to erase external storage devices.
- Added support for creating a folder-based snapshot volume dedicated to one shared folder.
[Bug fixes]
- Fixed an issue where certain NAS models with the network expansion card LAN-10G2T-X550 installed would display network speed incorrectly.
- Fixed an issue where Xbox One could not display multimedia files on the NAS after Media Streaming Add-on was installed.
- Fixed an issue where users could not delete the subfolders on external drives via SMB.
- Fixed an issue where certain input method settings in HybridDesk Station would change after users logged in again.
- Fixed an issue where Web Server would be automatically disabled and could not be enabled again when WebDAV was enabled after Surveillance Station and Plex Media Server were installed.
- Fixed an issue where iSCSI targets could not be connected when virtual switches were used and Service Binding was enabled.
- Fixed an issue where Windows File Explorer would not respond after users copied and pasted files within the same shared folder when connected to the NAS via SMB.
- Fixed an issue where checking disk usage in Media Library would cause CPU usage to increase after a large number of media files were uploaded to the NAS.
- Fixed an issue where RTRR jobs would be abnormally terminated when root folders were selected as the source folders.
- Fixed an issue where the system would force a line break within a long word in Network and Virtual Switch.
- Fixed an issue where only 100 folders would be available when users signed in to Google Drive via File Station after uploading more than 100 folders to Google Drive.
- Fixed an issue where advanced folder permission settings in File Station would become empty after users clicked the "X" button on the top-right corner to close the "Properties" window and then started the window again.
- Fixed an issue where users could not keep the changes made to certain checkboxes in Media Streaming Add-on after clicking "Apply All".
- Fixed an issue where Media Library would not respond when scanning and creating thumbnails for a large number of media files.
- Fixed an issue where App Center would not display the updated version of third-party XML files after users refreshed the page.
- Fixed an issue where Samba folders mounted from Ubuntu would prevent user access to subfolders added from Windows in File Station.
- Fixed an issue where minor page faults would occur in Network and Virtual Switch, which might cause CPU usage to increase.
- Fixed an issue where the background script in Network and Virtual Switch would constantly check network information, which might cause CPU usage to increase.
- Fixed an issue where CPU usage might increase after users clicked Resource Monitor numerous times.
- Fixed an issue where password-protected volumes might not be able to revert to snapshots.
- Fixed a myQNAPcloud certificate validation vulnerability (CWE-295).
[Notice]
- QTS 4.3.x is the final available firmware update for the following models:
TS-112P, TS-212P, TS-212-E, HS-210, TS-112, TS-212, TS-121, TS-221, TS-421 TS-120, TS-220, TS-420, TS-420U, TS-421U TS-412, TS-412U, TS-419U, TS-419U , TS-419U II, TS-119P II, TS-219P II, TS-419P II, TS-119P , TS-219P , TS-419P , TS-119P, TS-219P, TS-419P, TS-119, TS-219, TS-419
#283 Message par flacon030 »
QTS 4.3.3.0136 Build 20170328 Beta2
[Bug fixes]
- Fixed an issue where Samba would not function as expected after the NAS restarted when an external storage device was connected.
- Fixed a vulnerability in a configuration file that could be exploited to compromise the security of sensitive data. (CVE-2017-5227)
- Fixed an Apache HTTP Server vulnerability that could be exploited to deny requests to a server. (CVE-2016-8740)
- Fixed a stack overflow vulnerability that could be exploited to gain control of the EIP register.
- Fixed a SQL injection vulnerability that could be exploited to execute arbitrary SQL commands
- Fixed a command injection vulnerability in transcoding that could be exploited to execute unauthorized commands.
- Fixed a heap overflow vulnerability.
- Fixed a cross-site scripting vulnerability that could be exploited to inject arbitrary JavaScript commands.
- Fixed 2 stack overflow vulnerabilities that could be exploited to cause segmentation faults and gain control of the EIP register.
- Fixed a command injection vulnerability that could be exploited to execute unauthorized commands. (CVE-2017-6361)
- Fixed a command injection vulnerability that could be exploited to gain administrator privileges and unrestricted access to sensitive data. (CVE-2017-6360)
- Fixed a command injection vulnerability that could be exploited to gain the administrator privileges and execute unauthorized commands. (CVE-2017-6359)
- Fixed an access control vulnerability that would incorrectly restrict authorized user access to resources.
- Fixed 2 stack overflow vulnerabilities.
- Fixed an issue where users could not simultaneously perform multiple file copying tasks in a NAS shared folder mounted on a Mac via AFP.
- Fixed an issue where Media Library could not create thumbnails for certain JPEG files.
- Fixed an issue where users could not import the .ovpn configuration file created by QVPN to an OpenVPN client program in certain situations.
- Fixed an issue where a USB Wi-Fi dongle could not be detected again after the dongle was disconnected and reconnected to the NAS.
- Fixed an issue where the IP addresses of adapters in Network & Virtual Switch would be displayed incorrectly after QRM Beta 0.9.0 was installed.
- Fixed an issue where the CPU usage would spike regularly every 30 seconds when users logged in to the NAS via the web console.
- Fixed an issue where the network mode of a virtual switch created in Container Station would change from NAT to Bridge after a physical adapter was added to the virtual switch.
- Fixed an issue where Backup Station would not display available destination folders on a remote NAS where the log-in password contained the characters %^&*() when users created a RTRR FTP job.
- Fixed an issue where Storage Manager could not correctly report the health status of certain disks that had I/O errors.
- Fixed an issue where folders named in Korean or Japanese would not be arranged correctly in File Station when sorted by their names.
- Fixed an issue where Dashboard would not display the names of static volumes in error messages.
- Fixed multiple network vulnerabilities in QTS.
#284 Message par flacon030 »
QTS 4.3.3.0154 build 20170413
[Important Notes]
- Important: QTS 4.3.x runs on a 64-bit system architecture and may not support some 32-bit applications. To check if installed apps on your NAS are compatible with QTS 4.3.x,
download the QTS 64-bit compatibility tool and install it on your current QTS build.(http://download.qnap.com/QPKG/CF64_0.1-1114.qpkg.zip)
TS-112P, TS-212P, TS-212-E, HS-210, TS-112, TS-212, TS-121, TS-221, TS-421 TS-120, TS-220, TS-420, TS-420U, TS-421U TS-412, TS-412U, TS-419U, TS-419U+,
TS-419U II, TS-119P II, TS-219P II, TS-419P II, TS-119P+, TS-219P+, TS-419P+, TS-119P, TS-219P, TS-419P, TS-119, TS-219, TS-419
- The release of QTS operating system for the models that are not included in the support list will be coming soon. For the status of QTS updates and maintenance for your NAS model,
visit https://www.qnap.com/en/product/eol.php
[New Feature]
QTS
QTS Desktop
- More customization options have been added to the login screen.
Resource Monitor
- Added the Resource Monitor QTS App.
Audio Alert
- Added additional audio alerts
Notification
- Added a firmware update notification.
- Added browser notifications.
CIFS/SMB
- Added support for Samba 4.4.
Domain Security
- Added support for redundant domain controllers.
Security
- Added support for certificates from Let's Encrypt.
- Users can now be forced to change their passwords on a regular basis.
Users
- Privilege settings have been added for domain users.
Storage Manager
- Added the ability for Qtier to automatically tier data when the CPU/system is idle.
- Added support for the linear expansion of static volumes through expansion units.
- Added new disk icons in Storage Manager to help distinguish between HDDs and SSDs.
- Added support for creating read/write cache with single drive, RAID 0, RAID 1, and RAID 10 configurations.
- Users can now obtain support for exFAT file system through purchasing the exFAT driver license.
- Added support for installing up to 4 REXP-1000 Pro expansion units on the TVS-x73 series.
Snapshot
- Added support for snapshot timeline mode.
SnapSync
- Added support for replicating snapshot vault volumes/LUN to the another remote snapshot vault.
Time Machine
- Time Machine now supports the SMB protocol.
File Station
- Added a rename policy for filename conflicts when copying/moving files.
- Settings are now provided for other NAS users to use on-the-fly transcoding.
- Remote connection now supports automatically finding local devices.
- Enhanced the File Station UI to provide a better user experience.
- Enhanced the UI of the share link page on mobile devices.
- File integrity is now checked when copying/moving files.
- Qsync team folders can now be accessed in File Station.
- Add support for creating a snapshot shared folder with dedicated volume.
FTP
- FTP connections can now have higher speed transfers.
NFS
- Added support for NFSv4
- NFS now supports IPV6
iSCSI
- The unmapped iSCSI LUN list has been added to the to iSCSI Target List.
Network
- Port trunking general warnings have been replaced with individual warnings.
- Users can now examine the change in network status after a system restart.
- Network & Virtual Switch now provides Basic Mode and Advanced Mode to meet different needs.
- Virtual Switch
(1) Added support for the combination of different physical adapters, virtual adapters. of virtual machines, virtual adapters of containers, and Thunderbolt interfaces.
(2) Added support for STP (Spanning Tree Protocol) to prevent network loops.
(3) Added support for NAT (Network Address Translation).
(4) Virtual switches can now be set as the default gateway.
QVPN
- Integrated VPN Server and Client into QVPN Service.
- Added support for L2TP/IPsec VPN clients.
- OpenVPN clients now support importing OVPN files to establish connections.
- Added support for domain users to use VPN services.
Web Server
- Added support for HTTP/2 (x86 models only).
Photo Station
- Keyboard shortcuts can now be used the media viewer.
- Enhanced the UI for multi-zone streaming controls.
- Integrated media folder settings from the Control Panel.
- Enhanced the Manage Mode UI (Integrated albums and smart albums).
- Added support for advanced folder permission settings.
- Added support for domain users to log in.
Music Station
- Added multimedia streaming support for Sonos devices.
- Enhanced the Music Station UI to provide a better user experience.
- Added an advanced search function.
- Output devices can now be set for the Music Alarm.
- Added a mini player.
Video Station
- Improved the UI for multizone streaming.
- Subtitles can now be embedded into videos when playing them.
- Privilege controls have been added to multizone streaming and on-the-fly transcoding.
- Improved the video upload procedure.
- Improved the UI for opening share links.
- Added support for LDAP users.
- Bookmarks can now be added to videos.
- Added the ability to download information from TheTVDB.
- Files over 2GB can now be uploaded.
- Subtitles can now be displayed for MKV and ISO files.
- Videos can now be uploaded to YouTube and Youku.
- Different audio tracks are now supported.
- Improved the UI for TV series information.
Download Station
- Users now can monitor the seeding progress.
- Users can now monitor the progress of downloading FTP folders.
- Enhanced the Download Station UI to provide a better user experience.
- Open source add-ons can now be added to Download Station.
- Specific network interfaces for Download Station can now be set up.
Help Center
- Enhanced the Help Center UI to provide a better user experience.
App Center
- Apps can now send notifications and be automatically updated.
Installation
- Added support for establishing CloudLink connections during Cloud installation.
[Enhancement]
QTS Desktop
- Enhanced the interface of the log-in screen and QTS desktop.
Kernel
- Adds 64 bit support for firmware and apps for x86-based NAS (TS-x51, x53, x63, x69, x70, x71, x79, x80, x82, x89 series and IS-400 Pro).
Database
- Added support for MariaDB 5.5.51
Event Logs
- Users can now choose to compress the automatically saved logs.
Notification
- Enhanced the Notification UI.
- Enhanced the user interface of notification emails.
- Enhanced the push service.
Shared Folder
- A warning message has been added to confirm the removal of shared folders.
Snapshot
- A warning message has been added to inform users about apps that may be affected when the contents of a snapshot are restored.
- When reverting to a snapshot, a warning message will now display apps that will be affected after the reversion.
- Enhanced the Virtualization Station UI to provide a better user experience.
Web Server
- Added support for PHP 5.6
Firmware update
- Users can now choose intervals to check for firmware updates.
QTS-Misc
- Warning event notifications are now provided when volumes are locked.
[fixes]
- Fixed an issue where an error message would occur when users tested the camera configuration on QUSBCam after updating QTS to 4.3.2.0026.
- Fixed an issue where users could not connect to the Internet using PPPoE 2.1.0 after updating QTS to 4.3.2 or 4.3.3.
- Fixed an issue where non-administrator users could not upload files with alternate data streams to the NAS.
- Fixed an issue where the name of guest users who connected to the NAS via Samba would be incorrectly displayed on the "Online Users" list.
- Fixed an issue where users could not upload files that were larger than 3 GB via SMB to an external drive whose file system was FAT32 or EXT3.
- Fixed an issue where the NAS could not wake up from Sleep Mode after users created a port trunking group in the Balance-alb mode.
- Fixed an issue where Storage Manager could not display certain types of external drives when these devices were connected to the NAS via USB 2.0 ports.
- Fixed an issue where users could not create a domain account on Gmail Backup after updating QTS to 4.3.3.0095.
- Fixed an issue where entries erroneously reporting fan failures would appear on the system logs on the TS-831X.
- Fixed an issue where users could not create port trunking groups when "Force secure connection (HTTPS) only" was enabled in Control Panel.
[Other Changes]
- Download Station
Users can now be notified when downloads complete (instead of when download tasks complete).
- Added support for the USB 3.1 PCIe card USB-U31A2P01 on the following NAS models: TVS-463/663/863/863+, TS-563, TS-463U/863U/1263U, TVS-471/671/871, TVS-471U/671U/871U, TVS-682/882/1282, TVS-682T/882/1282T, and TES-1885U/3085U.
- Virtualization Station
Due to advancements in the backup features, virtual machines created in older versions (1.x/2.x) of Virtualization Station can no longer be backed up and restored in 3.0. (A workaround is to clone an older Virtual Machine; the cloned VM can be backed up/restored, but all original snapshots will be removed)
- After updating the NAS managed by Q'center to 4.3.2, the administrator of Q'center must input the password of each NAS at Q'center Server to continue monitoring.
- TwonkyMedia is no longer supported. Use the DLNA Media Server built into QTS as your DLNA server.
#285 Message par flacon030 »
QTS 4.3.3.0229 build 20170624
[Important Notes]
- For the status of QTS updates and maintenance for your NAS model, visit https://www.qnap.com/en/product/eol.php
- When QTS 4.3.x is installed on NAS models running on 64-bit Intel and AMD processors, some applications may not be supported. To check if installed apps on your NAS are compatible with QTS 4.3.x, download the QTS 64-bit compatibility tool and install it on your current QTS build. (https://download.qnap.com/QPKG/CF64_0.1-1114.qpkg.zip)
TS-112P, TS-212P, TS-212-E, HS-210, TS-112, TS-212, TS-121, TS-221, TS-421 TS-120, TS-220, TS-420, TS-420U, TS-421U TS-412, TS-412U, TS-419U, TS-419U+, TS-419U II, TS-119P II, TS-219P II, TS-419P II, TS-119P+, TS-219P+, TS-419P+, TS-119P, TS-219P, TS-419P, TS-119, TS-219, TS-419
[Enhancements]
- Improved the compatibility of the third and fourth drive bays on the TS-451A with high-capacity hard drives.
[Fixes]
- No disk I/O errors occur when an external storage device is selected as the destination for cloud-to-local sync jobs on Hybrid Backup Sync.
- Download Station does not lose connection when multiple download tasks are completed in a short period of time.
- The NAS can still join an Active Directory domain when SMB 1 is disabled on the Active Directory server.
- No connection issues occur when users access certain VPN servers via L2TP/IPSec or OpenVPN using QVPN.
- Domain users can access shared folders after installing a certain Qfix and then restart the NAS.
- The configuration of the DHCP server of the USB QuickAccess port does not affect the DHCP service in Container Station.
- Subtitles can be correctly displayed when users play .mp4 files on File Station.
- VJBOD disconnections do not cause Download Station to stop even when the download locations of download tasks are on the VJBOD volumes.
- Fixed multiple security vulnerabilities regarding input validation and access control.
- Temporary folders can be successfully deleted after users finish backing up files from the QNAP NAS to non-QNAP NAS devices via RTRR.
- Users can successfully delete a large number of LUNs using Cinder without causing Storage Manager interface to stop responding.
- The system does not erroneously display the message "update failed" when users enable or disable antivirus in Control Panel.
[Other Changes]
- In this update, RAID scrubbing is automatically scheduled. RAID scrubbing checks the data integrity of all RAID 5 and RAID 6 groups on the NAS. Running this check regularly is recommended. Storage performance might be degraded while RAID scrubbing is running. You can modify the schedule at "Storage Manager" > "Global Settings" > "RAID Scrubbing".
- After updating the NAS managed by Q'center from 4.2.x to 4.3.x, the administrator of Q'center must input the password of each NAS to continue monitoring.
